Shutdown
Allows you to shut down or restart a local or remote computer. Used without parameters, shutdown will logoff the current user.
Syntax
shutdown [{-l|-s|-r|-a}] [-f] [-m [\\ComputerName]] [-t xx] [-c "message"] [-d[u][p]
x:yy]
Parameters
-l : Logs off the current user, this is also the defualt. -m ComputerName takes precedence.
-s : Shuts down the local computer.
-r : Reboots after shutdown.
-a : Aborts shutdown. Ignores other parameters, except -l and ComputerName. You can only use -a during the time-out period.
-f : Forces running applications to close.
-m [\\ComputerName] : Specifies the computer that you want to shut down.
-t xx : Sets the timer for system shutdown in xx seconds. The default is 20 seconds.
-c "message" : Specifies a message to be displayed in the Message area of the System Shutdown window. You can use a maximum of 127 characters. You must enclose the message in quotation marks.
-d [u][p]
x:yy : Lists the reason code for the shutdown. The following table lists the different values.
rather than installing any softwares you can change use this and set the time for shutdown
good music lover like me!!!enjoy
