Old 22-05-2007, 09:09 PM   #1 (permalink)
Stay Silent!
enticer86's Avatar
Default Startup Checkdisk
Hi guys... when the computer is not properly shutdown then it shows an error msg where it asks to run the scandisk n we can hit any key within 10 secs to avoid it...
Is there any way possible NOT to get this option? I want it to forcefully run the checkdisk option, since everbody invariably presses a key to avoid it wich may harm my system in the long run
I saw me running,
'Twas a long, long run.
But the view was so stunning,
And that made it so much fun... ©
enticer86 is offline
Old 22-05-2007, 09:45 PM   #2 (permalink)
Distinguished Member
anandk's Avatar
Default Re: Startup Checkdisk
u can use tune-up utilities.system control > start & mntnce and set the time there to 0.
else if u dont have tune-up, try this ;
regedit > HKEY_LOCAL_MACHINE\System\CurrentControlSet\Contro l\Session Manager .
on the right side look for 'AutoChkTimeOut'
if its not there > rightclick>New>Dword value.
Rename it as 'AutoChkTimeOut'. now double click it and give the desired time delay in seconds. keep it 0 so that there wont be a countdown. click ok. reboot.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
CheckDisk running during starup guhanath Software Q&A 2 05-04-2007 10:58 PM
Checkdisk stuck on checking 3 drives thetopcyborg Software Q&A 7 14-10-2006 11:35 PM
i have a problem running checkdisk viruses Software Q&A 8 22-11-2005 09:52 PM
avg startup karthik316_2003 QnA (read only) 8 24-05-2005 10:03 PM
Help ,I cant use checkdisk on my win xp [C:\] drive[NTFS] Hitoriki Battousai Software Q&A 1 28-08-2004 09:40 AM
