Old 22-05-2007, 04:07 PM   #1 (permalink)
BlackBerry Guru ! :)
BBThumbHealer's Avatar
Unhappy uTorrent Speeds Issue
hey guys...
nowadays i m facing a strange prb... earlier when i used to download thru utorrent ..i got regular speeds of 20kBps at day n 40kBps at night....
but now the speeds get stuck at 8 kBps to 12 kBps in day n 20 kBps at nite .....moreover the torrent file which i m downloading has got good no. of seeds [ 10 K ] n around 1500 peers.... all the settings are applied to the max...even the port is forwarded properly...this issue is not only wid XP but wid Vista too...
when i directly download a file from the net..i get a constt speed of 20 kBps in day n 40kBps at nite...
haven't tried any other client...tried bit comet but wasn't satisfied wid it..
so hope that u ppl find a soln for it...
thnx
BlackBerry7100g...
Username Changed - BlackBerry7100g To BBThumbHealer ! :D
BBThumbHealer is offline
Old 22-05-2007, 05:21 PM   #2 (permalink)
Resident Fanatic
Manshahia's Avatar
Default Re: uTorrent Speeds Issue
which plan are you on??
Manshahia is offline
Old 22-05-2007, 05:32 PM   #3 (permalink)
HELP AND SUPPORT
rakeshishere's Avatar
@BlackBerry7100g
See HERE
Hope This Helps
rakeshishere is offline
Old 22-05-2007, 05:39 PM   #4 (permalink)
Rebooting
Choto Cheeta's Avatar
He He, I was searching for ur Post
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 22-05-2007, 05:47 PM   #5 (permalink)
Web Design Hobbyist
just check ur connection status or may the torrent seeders are less!!!
Neel Kamal Kalita
Web: http://neelsworld.in
dreamzchm is offline
Old 22-05-2007, 06:29 PM   #6 (permalink)
HELP AND SUPPORT
Just Came in to the rescue..
Old 22-05-2007, 08:51 PM   #7 (permalink)
guys....the main prb is that evrything was working fine.....its only nowadays that my speed has got reduced to 50%.....
and rakeshishere.....nice tut but have done evrything ...prb still persisting..
Old 22-05-2007, 09:02 PM   #8 (permalink)
Rebooting
@BlackBerry7100g
Hope u are not limiting ur Upload speed as Limiting upload will Limit download too...
rebooting
ChotoCheeta.com
Old 23-05-2007, 11:03 AM   #9 (permalink)
i have set the upload speed to 0 i.e unlimited
Old 23-05-2007, 11:30 AM   #10 (permalink)
gooby pls
Third Eye's Avatar
Try Azureus
Third Eye is online now
Old 23-05-2007, 11:52 AM   #11 (permalink)
Tried Transport encryption? prolly u are capped on P2P traffic during daytime.
Originally Posted by Tech Genius
Try Azureus
Are u on Azureus vuze or Azureus 2.5.4 ?
Faun is offline
Old 23-05-2007, 12:14 PM   #12 (permalink)
gooby pls
Third Eye's Avatar
I am using utorrent
Old 23-05-2007, 01:02 PM   #13 (permalink)
I am using utorrent
I was once a utorrent fanatic but this JAVA thingy got a hold of me. And speed remains around 30KBps, though it takes a lil bit more mem but its worth for the high definition contents its deliverin
Faun is offline
Old 23-05-2007, 05:45 PM   #14 (permalink)
HELP AND SUPPORT
I depends on No of Seeders for the Torrent,Network Settings,Port you use and Other minimal settings...Just Follow the Tut as i have Mentioned..U will see a Boost after u have tweaked it
Old 23-05-2007, 08:45 PM   #15 (permalink)
Try Azureus
i like azureus but not Vuze ...therefore won't like to switch to it...but still i'll try wid it
Old 23-05-2007, 10:33 PM   #16 (permalink)
This web page should help those using utorrent:-
http://www.johntp.com/2006/04/19/how...s-of-utorrent/
All the best.
vkr15
vkr15 is offline
Utorrent wizrulz QnA (read only) 2 20-12-2006 10:16 PM
What is this in utorrent ? manas QnA (read only) 2 26-11-2006 12:12 PM
Utorrent gau_pppu Software Q&A 5 17-11-2006 06:44 PM
utorrent error!!!! help me... gauravakaasid QnA (read only) 6 27-09-2006 02:01 AM
airtel, slow download speeds and gr8 ul speeds. legolas Broadband and DTH 6 26-08-2005 07:47 PM
