Old 20-05-2007, 06:04 PM   #1 (permalink)
bbalegere's Avatar
Default SATA RAID Confusion and Optical Drive Confusion
I am planning to buy a new computer with the motherboard Asus P5B-VM
This motherboard according to Asus website has the following connectors
for storage
South Bridge
-4 x SATA 3.0GB/s ports JMicron JMB363 PATA and SATA Controller
-1x UltraDMA 133/100/66/33 for up to 2 PATA Devices
-1 x Internal SATA 3.0Gb/s
-1 x External SATA 3.0 Gb/s port(SATA ont eh go)
-Support SATA RAID 0,1 and JBOD (by 1x External SATA & 1x Internal SATA)
If I buy 2 80GB SATA Seagate HDD(internal) can I do RAID Striping to boost performance?
If yes to which port should it be connect to.
According to the specification there 4 x SATA 3.0Gb/s ports JMicron Controller.
What is the difference between these 4 ports and the 1 x Internal SATA and 1 x External SATA?
Also to which ports are Optical Drives connected to?
I am planning to buy to DVD Writer with Light Scribe Technology.
Which brand and which is should I go for?
PLease help me.
Regards
BBalegere
bbalegere is offline
Old 20-05-2007, 06:21 PM   #2 (permalink)
"The Gentleman"
vish786's Avatar
Default Re: SATA RAID Confusion and Optical Drive Confusion
i dont think their is much diff in external and internal sata port... external port is just making things easier... so their is no need to open the cabinet and connect 2 internal sata.
"The use of COBOL cripples the mind; its teaching should, therefore, be regarded as a criminal offense."
- Dijkstra
vish786 is offline
Old 20-05-2007, 07:00 PM   #3 (permalink)
The DVD writer can be connected to the PATA, preferably as master. Or else try to buy a SATA DVD writer but it is not easily available, I think.
The "1 x External SATA" probably means an eSATA port for connection to compatible external devices.
For raid, why not connect them to the JMicron ports? Raid 0 should give some improvement in performance.
V.Prem Kumar
janitha is offline
HDD Confusion codename_romeo Hardware Q&A 3 30-12-2006 12:38 AM
Ram Confusion In My Pc - Please Help chnsfront2222 QnA (read only) 3 02-10-2006 10:47 AM
Ram Confusion In My Pc - Please Help chnsfront2222 QnA (read only) 2 01-10-2006 01:44 PM
Help!! Big Big Confusion!! ::vicky:: Mobiles and Tablets 20 25-09-2006 11:17 AM
AGP Vs VGA confusion???? taken QnA (read only) 1 11-04-2005 07:30 PM
