Old 17-02-2005, 04:34 PM   #1 (permalink)
The Hardware Labs
mohit's Avatar
Default Should i apply XP SP1 before APPLYING SP2 ?
Should Windows XP SP1 be applied prior to applying SP2 ?? Is it necessary ?
mohit is offline
Old 17-02-2005, 05:04 PM   #2 (permalink)
no not necessary. SP2 contains all the patches in SP1 and more.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 17-02-2005, 05:15 PM   #3 (permalink)
yes u can straight install sp2
atool is offline
Old 19-02-2005, 03:25 AM   #4 (permalink)
Sp2 contains all patches for security etc
dont install sp1
sp2 will do work for sp1 also!!!!!
neerajvohra is offline
Old 19-02-2005, 05:21 AM   #5 (permalink)
enoonmai's Avatar
Once you install SP2, or get the SP2 setup/disc handy, make sure you create a slipstream install disc of Windows XP to avoid installing SP2 after reinstalling Windows XP the next time around. Slipstreaming will make sure the SP gets integrated into the install process.
Playing FEAR XP/LSW2
enoonmai is offline
