Old 20-05-2007, 01:03 AM   #1 (permalink)
CG Artist
gaurav_indian's Avatar
Angry My system cant detect two SATA hard drives at the same time.Help!
My sysetm config
PD 3.0,Intel 945 mobo,80GB HDD SATA Seagate
Today i bought another SATA hard disk of 200 GB Seagate.Now the problem is my system is not detecting it with the older one.New hard disk is working fine if i remove the older one but they are not working together.May be you guys can help.I dont know about jumper settings.grrrr
gaurav_indian is offline
Old 20-05-2007, 01:13 AM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: My system cant detect two SATA hard drives at the same time.Help!
have U tried ur new hard disk on all SATA port .
ravi_9793 is offline
Old 20-05-2007, 01:26 AM   #3 (permalink)
CG Artist
Yes.One more question two SATA disks can work together?
Old 20-05-2007, 01:40 AM   #4 (permalink)
TechTin.com
ravi_9793's Avatar
yes,I am having two seagate SATA hard disk on my intel 915 hard disk.And U have intel 945 series which I think support upto 4 SATA hard disk.
Hey,does ur new hard disk give little vibration when given power???(when both hard disk are connected).Plz post ur reply.
Old 20-05-2007, 08:16 PM   #5 (permalink)
CG Artist
Problem solved thanx for your replies guys.It wasnt working due to the problem in the connector(power supply),i have changed it and now its working fine.
Old 21-05-2007, 01:48 AM   #6 (permalink)
TechTin.com
ravi_9793's Avatar
welcome friend...........and congrates for getting ur problem solved.
SATA ROCKS : Fujitsu intros first 2.5" 7200 rpm hard drive with SATA 2.5 interface techtronic Technology News 7 22-03-2009 11:09 PM
Sata-II hard disk working at Sata-I mode Arsenal_Gunners Hardware Q&A 27 17-03-2009 10:18 PM
PLz HELP! FC 6 couldn't detect sata Hdd Adhip007 Open Source 10 03-02-2007 06:50 PM
Fedora Core 3 won't detect SATA Apollo Open Source 2 30-01-2007 08:13 PM
