Old 19-05-2007, 08:12 PM   #1 (permalink)
gaurav21r's Avatar
Question NTFS vs FAT
Hey ppl my comp repair guy recently installed a new Hard Disk... The Seagate Baracuda 80GB....is it a good one?
I found that 2 partitions were created like always, but this time C: is 20 GB FAT32 while D: is 55 GB NTFS...
Is it okay for 2 partitions to have different file systems?
Plus which is better and suitable for which type of work b/w FAT32 and NTFS
do i have to write something here?????
gaurav21r is offline
Old 19-05-2007, 08:24 PM   #2 (permalink)
gooby pls
Third Eye's Avatar
Default Re: NTFS vs FAT
Yes
Yeah
NTFS is better
See why -> http://www.ntfs.com/ntfs_vs_fat.htm
Third Eye is online now
Old 19-05-2007, 08:27 PM   #3 (permalink)
1337 |)00|) \m/
kaustav_geek's Avatar
This might help you decide..
My Blog : www.vatsuak.blogspot.com
My DA page : www.burningsilver.deviantart.com
OK..ok..... Ads are bad.. ;)
kaustav_geek is offline
Old 19-05-2007, 08:34 PM   #4 (permalink)
eagle_y2j's Avatar
but for me FAT32 is gud option as it is having default read and write support from Linux OS
Registered LINUX USER #438929
eagle_y2j is offline
Old 19-05-2007, 08:37 PM   #5 (permalink)
sachin_kothari's Avatar
ntfs can also be read and written from linux. but yes, u have to configure it (atleast in Debian).
sachin_kothari is offline
Old 19-05-2007, 08:42 PM   #6 (permalink)
1337 |)00|) \m/
Yes, thats very true. But I'd recommend FAT32 for one more reason... In case something goes wrong with your WIN installation, and you need to backup data using some Boot disk, Sometimes, NTFS isn't supported and you end up getting screwed...
Old 19-05-2007, 08:44 PM   #7 (permalink)
eagle_y2j's Avatar
i prefer FAT32 for default read and write support ....its less messy
Old 19-05-2007, 08:48 PM   #8 (permalink)
left this forum longback
praka123's Avatar
wait for sometime more for the work @ http://linux-ntfs.org for their final software.
afaik ntfs-3g is a beta software ofcourse based on the work of http://linux-ntfs.org project ppl.
praka123 is offline
Old 19-05-2007, 08:53 PM   #9 (permalink)
TheSaint
NucleusKore's Avatar
Talking Re: NTFS vs FAT
Instead let only C be FAT32, make other drives ext3, and use ext2ifs to read/write the ext3 partition from windows, that's what I do
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 19-05-2007, 08:56 PM   #10 (permalink)
eagle_y2j's Avatar
but is this matters for linux users FAT32 and ext2 (we can read write both )
Old 19-05-2007, 08:57 PM   #11 (permalink)
praka123's Avatar
I have all my datas in ext3 file system partitions.
praka123 is offline
Old 19-05-2007, 10:49 PM   #12 (permalink)
God of Mistakes...
Garbage's Avatar
hey guyz what u r talking abt ? Gaurav21r never asked for Linux with FAT.
@ gaurav21r
It is always better to have NTFS partitions than FAT / FAT32 partitions.
If u have any FAT32 partition then u can convert it to NTFS using windows command "convert"
Go to command prompt and type "convert /?" (without quotes)
Registered Linux User #468778
http://twitter.com/_Garbage_
Garbage is offline
Old 19-05-2007, 10:54 PM   #13 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
NTFS-3G is a stable software.. Its out of beta. http://www.ntfs-3g.org/
kalpik is offline
Old 19-05-2007, 10:56 PM   #14 (permalink)
18 Till I Die............
locked. already many threads on this topic have been put up. Nothing new I see here.
mehulved is offline
ntfs & fat 32 ssk_the_gr8 QnA (read only) 6 17-12-2005 03:12 PM
NTFS or FAT 32?! zerohourkill QnA (read only) 3 05-07-2005 10:01 AM
NTFS in XP?? hearthacker Software Q&A 1 31-05-2005 04:41 PM
ntfs reader not detecting my ntfs drive help expertno.1 QnA (read only) 3 24-05-2005 09:19 PM
Unable to mount all ntfs drives in fedora3.mount one ntfs, neerajvohra Open Source 1 06-02-2005 03:56 PM
