Re: installation problem!!
Why did you delete the Recovery Partition! Thats the most valuable feature in HP Laptops.
Instead of deleting the partition, you could have partitioned the 68GB further to 2 partitions. The other partition could have been used for Linux.
Anyway, since it's all over, Here is the method of installing Linux. The method is similar for all distros.
1. Make 2 partitions of your 12GB drive. viz. 11.5GB and 500MB partition. Here 500MB is a swap partition for Linux. You can install Linux without this partition. Linux will automatically create swap partition in the installation drive itself. But there will be decrease in performance. Hence I suggest you to make a swap partition prior to installation of Linux. Leave both the partitions unformatted.
So at this stage your HDD should look like this:
C:> 68GB
unformatted:> 11.5GB
unformatted:> 500MB
Note: Unformatted partitions will not be visible in "My Computer" of Windows.
2. After done with partitions, you are now ready to install Linux.
Insert the Fedora CD 1 and boot from CD
3. You will get a Fedora screen with "Release Notes" and "Next" tabs
4. Click "Next"
5. It will ask for Language of installation, select "English" and click "Next"
6. Appropriate Keyboard for your system - select "U.S. English"
7. Now it will prompt for partition types viz. Automatic selection, Manual selection. Select Manual Partition selection. This is very IMPORTANT to see that your Windows Partition is not wiped out. Click "Next"
8. All the partitions will be visible now. Select the 11.5GB partition and click "EDIT"
9. Make it as root. i.e. select "\" option from the list and the format as "ext2" and click OK
10. Now select 500MB partition and click "EDIT".
11. Select "SWAP" from the list and click OK
12. That's the most important parts of installation. Rest of the things are common things like Network configuration, Location..etc. Proceed with the installation.
You are done!. Enjoy.
Kiran Kumar R
