Re: plz help me to rectify this prob.
This error message has got nothing to do with RAM.
First of all find the location of ctfmon.exe. It should be located in C:\Windows\System32. If yes, then you have no virus infections. There are worms posing as ctfmon.exe located at other locations.
Now, coming to the problem, ctfmon.exe is a MS Office related system file. It is added as start-up entry by MS Office.
I think your Office suite is corrupted. So I suggest you to completely uninstall MS Office and reinstall it.
Revert back if problem prevails.
Kiran Kumar R
