LinkBack (1) Thread Tools Search this Thread Display Modes
Old 19-05-2007, 12:33 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Default why pc restart on command prompt.
hi guys
i think this question was asked earlier , but i could not get the answer finding it , the question is when i go ---run---type "cmd" , my pc gets restart .is it viros problem ? if no then please help.
suraj is offline
Old 19-05-2007, 05:38 PM   #2 (permalink)
napster007's Avatar
Default Re: why pc restart on command prompt.
sure dude.
i had a similar problem. its a virus. install avast antivirus. it'll take care of the rest.
napster007 is offline
Old 20-05-2007, 01:02 AM   #3 (permalink)
TechTin.com
ravi_9793's Avatar
I recomend you boot your system into safe mode and scan for virus's and trojans.
Also update your windows from microsoft website.
Also repair ur windows registry using some registry software.Some good and free registry fixer software can be found here:
http://www.techiehome.org/viewtopic.php?t=663
ravi_9793 is offline
Old 20-05-2007, 11:38 PM   #4 (permalink)
try COMMAND instead of CMD.
It will work without restarting.
Yes its a Trojan problem.
Faun is offline
Old 21-05-2007, 05:25 PM   #5 (permalink)
what is trojan ?
suraj is offline
Old 21-05-2007, 05:33 PM   #6 (permalink)
Trojan attaches itself with a file on internet which if downloaded then can send information about your computer and data to a hacker. By this hacker can have a full control on your pc.
abhijangda is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/qna-read-only/58187-why-pc-restart-command-prompt.html
Q&A: PC is Restarting when opening CMD through RUN command | TechRepublic This thread Refback 11-03-2011 01:34 PM
How to remove prompt to restart Suhas M Software Q&A 8 19-03-2007 03:46 PM
Command Prompt Help rishi1 QnA (read only) 2 20-07-2006 11:05 AM
command prompt problem bukaida QnA (read only) 2 22-01-2006 08:26 PM
Command prompt in xp suresh4ever QnA (read only) 1 10-01-2005 05:13 PM
