Old 17-02-2005, 02:04 PM   #1 (permalink)
rajat22's Avatar
Default Quick Lauch Bar
Quick Lauch Bar never loads with windows for a long time respite all of my known attempts.
Using XP Home with all updates in a P4 2.4 dual boot with win 98 machine with no other complaint.
rajat22 is offline
Old 17-02-2005, 06:52 PM   #2 (permalink)
swatkat's Avatar
this is a documented problem, happened to me too (long time ago)...
check that, u r having Quick Launch Folder in Internet Explorer folder.....
If u do not find Quick Launch Folder there, the path is:-
DriveName:\Windows\Application Data\Microsoft\Internet Explorer\
or
DriveName:\Windows\Profiles\UserName\Application Data\Microsoft\Internet Explorer\
do this...
Go to Start>Run and then type IE4UINIT.EXE and press Enter....this creates the Quick Launch folder, if it is not already there.
if u do have Quick Launch Folder, no need to do the above step, directly do this....
Go to Start>Run and type REGSVR32 /i SHELL32.DLL and press Enter, after this againg type REGSVR32 /i BROWSEUI.DLL and press Enter...
Then Restart.....
http://swatrant.blogspot.com/
swatkat is offline
