Old 17-05-2007, 05:42 PM   #1 (permalink)
9437077259
go4saket's Avatar
Default Can we have multiple net connections at a time?
Hi Guys!
Can we have multiple net connections at a time. I mean, is it possible o connect to the net using BSNL Broadband, BSNL Dial Up as well as Reliance Net connection, all running at the same time.
You must be thinking why do I need to do this. Well, actually I am in a business where I have to sit for some auctions and we get only one minute to bid in. Now, incase if we loose our net connection in that period, we loose whole months work. So I was just wondering that if I could have multiple connections, it can work as a backup connection. I hopw you got my point.
Thank you.
Win 7 Ultimate
Abit IP35-E Mobo,C2Q 6600,4GB DDR2 RAM,XFX 8600GT 256MB DDR3 Gfx ,Seagate 1TB HDD,Sony DVD RW,500w SMPS,19" Viewsonic VX922 TFT,Logtech G5 Mouse,Altec Lancing 2:1 Speakers.
go4saket is offline
Old 17-05-2007, 05:44 PM   #2 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Default Re: Can we have multiple net connections at a time?
Yep, you can have simultaneous connections AFAIK but i havent tried it
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 17-05-2007, 05:49 PM   #3 (permalink)
9437077259
go4saket's Avatar
How is the question?
Win 7 Ultimate
go4saket is offline
Old 17-05-2007, 05:52 PM   #4 (permalink)
Host4Cheap.org
HUH Didnt get u there
Old 17-05-2007, 06:08 PM   #5 (permalink)
harmax's Avatar
Hi Guys!
Thank you.
U can do it using bandwidth aggregation feature in windows, jus google the following keywords : windows bandwidth aggregation and ull get all the required info
WORK EXPANDS TO FILL THE TIME NEEDED FOR ITS COMPLETION
-------- PARKINSON\'S LAW
harmax is offline
Can I connect 2 internet connections Connect at a time? gaju6696 Internet & WWW 6 06-02-2009 08:26 PM
downloading on same pc using 2 connections at a time kuldeep bhardwaj Internet & WWW 8 01-08-2006 02:49 AM
Using Two Internet Connections at The same time siddharth> Software Q&A 6 17-07-2006 08:22 PM
multiple internet connections Gaurav Internet & WWW 6 27-05-2005 10:16 PM
Sharing multiple net connections shriekers QnA (read only) 3 03-04-2005 03:18 PM
