Old 17-05-2007, 12:33 PM   #1 (permalink)
Default please help i am truoble
hi friends i am using a assemble computer.my problem no sound is comming from fornt port means sound port kindly help so i cannot connect my headphone kindly help please please please
shriram_jairam is offline
Old 17-05-2007, 01:01 PM   #2 (permalink)
Default Re: please help i am truoble
may be you front audio jacks are not connected to your board. You can connected them from your rear audio jacks.
sushantsaurabh is offline
Old 17-05-2007, 01:34 PM   #3 (permalink)
My observation is that by default most of the motherboards come with sound output routed to back panel.
You may have to set the jumpers to route it to front ports. Check the manual to know the jumper settings. Plus ensure that the cabinet's front audio sockets are connected to the motherboard's front panel audio headers. Some cheap cabinets do come with front audio sockets but the wiring & connectors that can connect it to the motherboard is missing.
patkim is offline
Old 19-10-2008, 09:19 PM   #4 (permalink)
Kcots Hserf
trublu's Avatar
Sorry for bumping this age-old thread,but look at the title of the thread !!
ASUS K53SM-SX0101D | Samsung Wave 525 | Canon EOS 1000D | 18-55 mm | 50mm f1.8
Registered Linux User #471793
trublu is offline
Old 19-10-2008, 10:19 PM   #5 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
U r inviting trouble for urself!
About me:
http://about.me/preetam_nath
comp@ddict is offline
