Old 15-05-2007, 12:14 PM   #1 (permalink)
The Devil's Advocate
iMav's Avatar
Default MAC OS X - Truth Revealed
Well im starting this thread where some revelations about the MAC OS X will be discussed .... and believe me u will be surprised at some
also the goods wil be discussed
1. There's no Cut/Move option u can only copy paste between drives
in other words i download a song on a certain folder say desktop and if want to put in a folder songs somewhere else i will have to copy-paste it there and then delete it from where i dont want it
2. As in windows If u right click on a file and select another application to open it and select it to be set as default same is not the case in MAC ... here if u choose another application for a file it will be only for that file and not the file type
3. If u load ntfs drives they are loaded as connected servers (im still unable to make them writtable)
4. Dashboard & Expose are useful .... however at times i would say a sidebar for gadgets is better coz then i dont need to load another 'desktop' for accessing my gadgets
5. if u take a screenshot using grab and u want to save it with extension .jpg u can only save it with extension .tiff or xyz.jpg.tiff and if u choose .jpg.tiff here is the wierd part just remove the .tiff after saving the file and then it ecomes jpg file and the size shoots drastically
6. it also has a similar to aero effect ... ur menus are transparet
a lot more revelations will be coming
http://beingmanan.com
iMav is offline
Old 15-05-2007, 12:32 PM   #2 (permalink)
You gave been GXified
gxsaurav's Avatar
Default Re: MAC OS X - Truth Revealed
Well, from my own experience of the so called good UI/OS.
1) There is no Full Window concept. When you try to maximize a Windows it zooms to the size of content in it. This results in you having a lot of Windows on screen. Technically speaking this increases the load on Video frame buffer or Video memory. Mac UI is palate based, like in Photoshop there are 3 palates. Viewport, Toolbox & layers/history etc. To get an idea of how the plated UI of Mac is, try GIMP on Windows. It really hinders the usability, cos now Photoshop has 3 Windows, & all are separate entities. Just minimizing the viewport will not minimize Photoshop.
2) Dock shows all you frequent applications, but what about less frequent ones? There is no "Other apps" thing. The best way I was able to manage is to make a new folder "Applications" & put the shortcuts of non-frequent apps in it. Now to start these apps first click on the dock to open this folder & then the apps. This could have been solved if there was a Menu kind of option in dock
3) Non-Standard keyboard shortcuts.
4) The UI is white, & there is no inbuilt option in the OS to change it to something else like black. There is smooth stripe skin but comon.....it's gray.
5) WMA's doesn't play in iTunes, nothing does. Just mp3 & AAC. Despite of using aac it doesn't sync with my K750i.
Quicktime doesn't full screens. You will need to pay $30 for full screen. The only must have option is VLC player for MaC. Installig Flip4Mac helps in quicktime but it is also a paid application & doesn't support wma in iTunes
There is no way I ould play my WMA in Mac. I had to install 3rd party application VLC Player. Out of the box the multimedia capabilites of Mac doesn't seem that right all of a sudden.
6) Also there is no PIM. I do not have access to outlook/office on Mac, & m seriously missing it. There are 3 seperate application such as Mail, Calender & Address book.
about.me/gxsaurav
gxsaurav is offline
Old 15-05-2007, 12:39 PM   #3 (permalink)
iMav's Avatar
and if u try to drag ur applications folder to the dock ... it gets deleted
iMav is offline
Old 15-05-2007, 01:04 PM   #4 (permalink)
C# Be Sharp !
Zeeshan Quireshi's Avatar
Mav , to add applications to the dock , you have to run them , then when they're running you have to right-click em n then select add to dock . whew , wuite an excersise just to add a shorcut to dock
seems like a Trio of mac users here
There are 10 types of people in the world: those who understand binary and those who do not.
Zeeshan Quireshi is offline
Old 15-05-2007, 01:10 PM   #5 (permalink)
gxsaurav's Avatar
Zeeshan come on yahoo.
You can open your applications folder & there you will see icons for many application. Drag those application to Dock that might make a shortcut of those apps insted of moving those apps to dock.
psst......we do not own a Macintosh :-"
about.me/gxsaurav
gxsaurav is offline
Old 15-05-2007, 01:22 PM   #6 (permalink)
iMav's Avatar
i finally added application folder to my dock ...
iMav is offline
Old 15-05-2007, 02:00 PM   #7 (permalink)
Kiran.dks's Avatar
Amazing facts! Why the hell is it praised so much? Just an eye candy!
It's time when people realize what exactly "productivity" mean. There is no doubt what-so-ever that Windows is miles ahead of Mac in this respect.
Kiran Kumar R
Kiran.dks is offline
Old 15-05-2007, 02:16 PM   #8 (permalink)
iMav's Avatar
there was a time when multimedia people used mac because some applications such as image editors, video tools were mac exclusive but now no more
and as i said i will also highlight some goods as compared to windows .. there are only a handful though
bluetooth:
it was absolutely easy for me to setup my fone with mac .. and the best part is tht it will detect what kind of fone u have and then send a file to ur fone which u install will sync ur fone with the pc and will easily transfer all contacts and calendars to the mac ... vista cant do it as effectively as mac can ... so bluetooth gets 10/10 in mac
iMav is offline
Old 15-05-2007, 02:23 PM   #9 (permalink)
gxsaurav's Avatar
There is also another reason. On a Mac, what u see is what u get (in colour). However with Windows XP the ability to use your own color profile system wide on any monitor took away this novelty of Mac
bluetooth:
Mac has bluetooth device onboard in the hardware, means no more using USB bluetooth stick. However file transfer using bluetooth is slow. My data cable of K750i isn't working to sync things thogh the memory card is visible. Vista does the same using bluetooth but only if you have a Windows mobile device.
Macboys, where are you, i need help in finding a proper Music Player other then iTunes for Mac. I thought it was said that Mac have thousands of application. Well, refer me to one which playes wma files.
about.me/gxsaurav
gxsaurav is offline
Old 16-05-2007, 12:18 AM   #10 (permalink)
iMav's Avatar
ah i forgot about this earlier ...
in a mac u can set the pc to emit sounds every hour or so u have a guy/gal/kid's voice tht will shout the time .... i find it cool besides not only tht u can add animation to the clock such tht ':' between the time will blink also u can have seconds display
dont know about wma but i found a stripped down msn messenger for mac by microsoft
hey chk out this widget it allows to type sms on dashboard then select the recipient from there (ur contacts are all thr if synced) then send sms thru fone via bluetooth ...
iMav is offline
Old 16-05-2007, 01:16 AM   #11 (permalink)
aryayush's Avatar
LOL! Reading some of your complaints gives me the impression that I am reading the posts of three year old kids.
Honestly, how intelligent do you have to be to properly drag a folder onto a dock? Or how much IQ does it require to at least try right clicking on a folder in the dock to see what happens!
Kids, play time is over. Mac OS X sucks. Uninstall it and get on with your lives.
Originally Posted by Kiran_tech_mania
Amazing facts!
Facts!!! Ha! Ha! Ha! Ha!
aryayush is offline
Old 16-05-2007, 01:25 AM   #12 (permalink)
iMav's Avatar
well its actually a little tricky to move a folder to the dock iw ill explain:
u cannot place a folder in the dock to ur left of the separator but u can do tht on ur right which 1 realises after trying a few times ...
and we aint complaining just highlightimg certain 'facts' about the mac os x which others didnt know
iMav is offline
Old 16-05-2007, 01:36 AM   #13 (permalink)
gxsaurav's Avatar
OMG ARE YOU ARYA, DID SOMEONE HACKED YOUR PASSWORD.
& no, atleast I don't intend to uninstall Mac. Why should I? Isn't it supposed to be the worlds best OS well, I m happy to use the worlds best OS right? We have problems so as a loyal macboy & a member of this forum it is your duty to help us.
Amazing facts!
Yup facts like
1) Mac doesn't play WMA out of the box
2) Doesn't have cut option
3) Doesn't comes with a messenger client which works with all protocalls out there (I mean to say adium which is free)
4) etc etc
This just in, I need to attach my Mobile phone to Mac using data cable. Any idea arya? if you are able to connect your SE W500i then My K750i can also be added.
about.me/gxsaurav
gxsaurav is offline
Old 16-05-2007, 02:36 AM   #14 (permalink)
iMav's Avatar
its a hackintosh
truth prevails some day it had to come out and it finally did
iMav is offline
Old 16-05-2007, 08:38 AM   #15 (permalink)
Kiran.dks's Avatar
Save some laughter for 'other' part of life. Hopefully I assume that you do have other world than the dreadful mac world.
Kiran Kumar R
Old 16-05-2007, 08:58 AM   #16 (permalink)
gooby pls
Third Eye's Avatar
Windows rocks man
Third Eye is offline
Old 16-05-2007, 09:19 AM   #17 (permalink)
left this forum longback
praka123's Avatar
Thumbs down Re: MAC OS X - Truth Revealed
First bashing Linux,Now MAC-sure those thread starters are Windows fan boys.its pity on u for such a childish try.
praka123 is offline
Old 16-05-2007, 09:32 AM   #18 (permalink)
sachin_kothari's Avatar
i am loving this windows v/s linux v/s mac.
makes for an interesting read.
sachin_kothari is offline
Old 16-05-2007, 10:26 AM   #19 (permalink)
gxsaurav's Avatar
Kiran, just like you even I doubt it , the only reason for that laughter I can find is "Amazement" & "jealousy" that we have pointed out in an unbiased manner where MacOS sux & where it kicks the hell out of Windows, which might have shocked the macboys regarding there "Perfect OS"
I guess, just like few other Macboys, arya also needs a life
Stop hijacking threads.
In that thread I didn't bash Linux for a moment, I bashed the applications cos an OS is as good as the applications are. In linux the state of applications isn't that gr8 right now. Now, plz mind from posting such hijacking comments. We are just making things clear & removing misconception of people who say Linux is good or Mac is good & will take over the world....we are just showing here why it won't beat Windows, something we have always done. Showing the facts.
@ sachin
This is not a flame war bhai, we all know the short comings of Windows right, some also know the shortcomings of Linux but no one knows the shortcomings of Mac cos it runs on Macintosh only. Well we now have access to it so it is high time we show the forum users where it sux & where it prevails compared to most dominating OS platform out there. Windows.
We go to the nearest Apple Shop & work on Mac there whole day, log in via safari find flaws & post them here.
about.me/gxsaurav
gxsaurav is offline
Old 16-05-2007, 10:54 AM   #20 (permalink)
C# Be Sharp !
and if we don't point out the shortcomings in an OS then how will developer's add new features and ammend fill up the shortcomings .
Mac users should consider it beneficial , coz now there's someone there to tell them what is wrong with their OS n that how it can be made better
mate , my motif is not to bash ny OS but to express what i feel is missing so that developers can provide that n that if it exists then other users can tell me how to use it . i've never really said that "linux is this , Win is that " i've always pointed out my problems objectively and that's what iMav n Saurav are doing too
Old 16-05-2007, 11:25 AM   #21 (permalink)
gxsaurav's Avatar
Posting flaws in an OS actully helps the developers in making it better. Isn't that what beta testing is for. Well, I guess atleast Mac developers know how much we miss a cut feature in Mac. Who knows maybe after 5 years of relesing MacOS X they will finally add this basic feature.
about.me/gxsaurav
gxsaurav is offline
Old 16-05-2007, 11:52 AM   #22 (permalink)
The Devil
blackpearl's Avatar
I guess there is no option to submit error report in a Mac, 'coz mac users don't believe there can be errors.
blackpearl is offline
Old 16-05-2007, 01:08 PM   #23 (permalink)
Kiran.dks's Avatar
They will refrain from doing it and instead say that cutting is not allowed as it's one of the core security feature to avoid loosing data due to inefficient copying!
Kiran Kumar R
Old 16-05-2007, 01:30 PM   #24 (permalink)
C# Be Sharp !
lolz
Old 16-05-2007, 01:37 PM   #25 (permalink)
gxsaurav's Avatar
lolz...there are errors indeed, but just like some macboys say "Whats the point of talking about a security bug :-", talking just makes it popular. So if there is a bug then keep quite about it & fix it. This way people will never know about the bug & Apple will sale there products"
ROFL dude...
I just can't believe the level of jealousy & anger in arya's post. I mean, comon....I am using an OS & pointing out the flaws, whats wrong in that? Didn't he do the same when he was using Windows Vista ? Did we got angry & told him "Vista sux uninstall it"
about.me/gxsaurav
gxsaurav is offline
Old 16-05-2007, 01:52 PM   #26 (permalink)
iMav's Avatar
linux and macs have to understand a simple thing ... windows is numero uno coz it is better than both coz of the features it provides and most of windows users are not cia, kgb, raw agents who require their machine to be absolutely secure running on 2048 bit ssl encrytion .... they will achieve nothing by hi-jacking threads and claiming that windows sux ... the fact is those posts give us an oppurtunity to tell others that windows is infact better in more ways than 1 and this thread also goes on to show the same
mac os x is the best implementation of the unix platform (undoubtedly) and it has some major basic flaws which are quite evident within 2 days of using it so well cant help it read my siggy
another problem in the mac is that u cnnot hide file extensions for even applications that the OS knows how to open/run for example my sify dialler works fine but the extension .jar cannot be hidden
iMav is offline
Old 16-05-2007, 02:07 PM   #27 (permalink)
 Macboy
goobimama's Avatar
This thread is a joke and should be merged with that joke thread that going on in the chit chat section....
I'm like a bird... :)
goobimama is offline
Old 16-05-2007, 02:09 PM   #28 (permalink)
aryayush's Avatar
OK, I'd thought I would just ignore this thread because everyone knows how baised the unbaised reviewers in this thread are. But apparently, the other users on this forum are just as stupid as the initiators of this thread.
You guys are acting like you are out here genuinely pointing out the pros and cons of the operating system. Well, I see none of the hundreds of things that Mac OS X does a lot better than Windows or that Windows does not do at all in this thread.
And the cons. You guys, after all your research, have come up with exactly two problems:
1. No option to cut and paste files between drives.
2. iTunes does not support WMA.
The first one is a genuine flaw and it is widely accepted. It will most probably be fixed in Leopard but anyway, it is a flaw. Point noted.
The second one is simple crap. No one expects iTunes and iPod to play WMA files and Apple will not give you this functionality. The 'DOC' format is a standard for documents so Mac OS X supports it. Windows Media formats are not the standard. AFAIK, they are used only for pornographic files. Windows Media Player does not play M4A files either and no one expects it too.
Oh, and BTW, there are media players on Mac OS X that do play Windows Media formats, starting with Windows Media Player itself. But if gx_saurav expects to rely on me for doing a basic search on MacUpdate, he'll be waiting forever because that aint gonna happen.
So, anyway, I challenge you (iMav and gx_saurav). Spend one week with the OS and then post every single flaw you come across in it. Post them pointwise, no matter how small they are. Let us see the best you can do. And then I'll do some myth-busting. Let's get started.
I know things will get rough so I'm starting a new thread in the Fight Club forum.
aryayush is offline
Old 16-05-2007, 02:11 PM   #29 (permalink)
iMav's Avatar
@arya dude looks like u jumped directly to this page and missed the rest of the points go thru the first page also theres a point by point brief of some flaws
@goobi actuallly the thread is not a joke but the posts are quite funny considering the fact that the so called best OS has some serious basics gone wrong
iMav is offline
Old 16-05-2007, 02:11 PM   #30 (permalink)
aryayush's Avatar
Exactly. I'm hoping goobimama will later assist me in some of that myth-busting with his excellent sense of humour.
aryayush is offline
Truth Happens:Linux Ad ~Phenom~ Open Source 19 14-05-2007 06:46 PM
What is the truth behind this browser? gauravgogiakavi QnA (read only) 6 15-02-2007 10:29 PM
whats the truth Binay 007 Gamerz 2 29-11-2006 11:02 PM
The truth about Taj Mahal blackpearl Fight Club 38 01-11-2006 01:27 AM
