Old 16-02-2005, 02:30 PM   #1 (permalink)
Default Size of data on CD :- 1.14GB
My friend gave me an 669 MB ISO file of some freewares and trial version on a CD (which he had downloaded from www.download.com). I opened the file & extracted to check whether the file was corrupted or not. The size of the folder in which all the files were extracted was 1.14 GB. I opened that ISO file through Nero 6.6.0.6 and burned it on a CD.
I checked the size of the disk and found that it was 669 MB. However when I checked the size of one of the folder it was 1.14 GB.
Any idea how this is possible???
Shikhar is offline
Old 16-02-2005, 03:50 PM   #2 (permalink)
Ethan_Hunt's Avatar
well here i assume that "after extration" means that ur folder had been compressed.....meaning that there are softwares like winzip and winrar and many other compression utilities to compress big chuck of files to certain extent....like for eg. a 6 Disc game can be heavily compressed using winrar to make it a 3 Disc version....also like in ur case the ISO Cd image that ur friend gave ya was actually a compressed folder of 669MB (Actual disc size) and after extraction it came to its original size i.e. 1.14GB....there are tons of utilities that can be used for compressing files....just google for em
here are a few
http://www.downloadfreetrial.com/uti...mpression.html
http://search.looksmart.com/p/browse...1694/us171733/
good luck 8)
Ethan_Hunt is offline
Old 16-02-2005, 10:17 PM   #3 (permalink)
Bewitched!
xenkatesh's Avatar
hi but.. whenever i try to compres around 900MB data of .pdf files it compress only to 825 when i increase the compression to maximum it goes upto 722 only.. any idea of compressing to half the size.....
Keep your friends close and enemy CLOSER!!!
Ragnarok Online: One World, One Million Possibilities.. :)
xenkatesh is offline
Old 18-02-2005, 12:12 AM   #4 (permalink)
aadipa's Avatar
nothing to do with compression
its a symbolic links working on cds
similar files in diff folders are stored on the cd only one. its links are entered into the file table so that every folder appers to have its own copy of such files.
u can use CDIMAGE software for creating such ISOs.
This technique is generally used in "n in 1" type of Windows OS CDs.
1 aadi + 1 aadi = 1 full ;)
aadipa is offline
Old 18-02-2005, 09:47 PM   #5 (permalink)
yeah aadi i thot of that too
infact id posted that a couple of months ago on the same topic
but this guy's talkin abt freeware/shareware on the cd
thats y i didnt post
i wonder how he did that unless he compressed it using some software
@allwyndlima
i think what he meantby extraction was extraction from the iso !!
@xenka use uharc
No Mercy, No Limits.
theraven is offline
Old 19-02-2005, 02:31 AM   #6 (permalink)
Iso making files works like compacting the data
rather than enlarging it to gb"ssssss
neerajvohra is offline
Old 19-02-2005, 05:35 AM   #7 (permalink)
swatkat's Avatar
as mentioned by raven, use uharc (one of the best compression algorithm), but it's DOS based tool, so to ease up the things there are GUI based tools, like WinUHA, the GUI tool, with the power of UHA and Uharc-GUI, another UHA based GUI tool...
Actually there's another format which gives better compression that UHA, it's called UDA. The tool is called WinUDA, a small GUI based software....
http://dwing.spymac.net/download/WinUDA28.zip
but keep in mins that, these softwares take a lot of time to compress....
http://swatrant.blogspot.com/
swatkat is offline
Old 19-02-2005, 12:54 PM   #8 (permalink)
Found some files common in all the folder. I think aadipa is right.
It is better to light a candle than to curse the darkness.
Shikhar is offline
