Old 16-02-2005, 12:35 PM   #1 (permalink)
Just Do It
Default Manual Download files always erroneous from the net
Alll the files or softwares manually downloaded from the Internet dont work and give an error as the 1 below
Program has peroformed an illegal operation and will be closed down
SECRETMAKERSETUP caused an invalid page fault in
module <unknown> at 0000:bff8b0fa.
Registers:
EAX=00000000 CS=0167 EIP=bff8b0fa EFLGS=00010213
EBX=00000000 SS=016f ESP=82664f3c EBP=82664fc4
ECX=c14fae10 DS=016f ESI=8166a2c0 FS=1277
EDX=bffc9310 ES=016f EDI=00455820 GS=0000
Bytes at CS:EIP:
89 18 e8 6f d9 00 00 85 c0 74 0d 80 4e 14 20 8b
Stack dump:
8166a2c0 81668408 81666fbc 00570020 bff8b2a7 81668408 00000008 81666fbc 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
This operation has benn cancelled due to restrictions in effect on this computer. Please contact your system adminstrator
Please help me as I cannot find a soln.......
Charley is offline
Old 16-02-2005, 12:50 PM   #2 (permalink)
Well this is what i feel i am not sure on this.
I am assuming you are using Windows Xp or 2000
Firstly is this your own PC or office PC because in a Office PC
normal users accounts are there , they dont have the rights to
install/uninstall a new software only the OS Admin can do it.
Are you logged in Windows XP as root user or Administrator
When you are trying to install any new software.
Because a normal user cannot install softwares on WinXp unless
he is logged in as Administrator.
When User Account settings are done the normal user login or guest login
in WinXP has no rights to install or uninstall anything from the system.
If you log in as Administrator and give it a try you might be able to
install softwares
Just give it a try and let me know if it has worked.
quad master is offline
Old 16-02-2005, 01:28 PM   #3 (permalink)
Just Do It
Its a systeem used a home......
And I have Win98 Se installed......
Charley is offline
Old 16-02-2005, 02:11 PM   #4 (permalink)
swatkat's Avatar
run System File Checker (sfc) once, do this:-
Go to Start>Run and type sfc and press Enter.
Then click Settings, There u Select/Check the option, "Check for Deleted Files" and click Ok.
After this,clicl "Scan for altered files" in the main window and click "Start".
This will scan ur system for any corrupt system files and prompts u to restore it from Win98 Setup CD or Win98 Setup Backup in ur Harddisk.
do u have recent Digit CDs? if u have them, please copy HijackThis from them, and post the log file....
Also, do an AntiVirus scan...
http://swatrant.blogspot.com/
swatkat is offline
Old 16-02-2005, 04:30 PM   #5 (permalink)
Just Do It
I did the sfc thru the run menu and it didnt ask for the Windwsbackup for any correction. It said that all scanned ......
And regdg hikackthis , i tried again downloading form the net , it said that the file has to be fixed , if yes it doesnt wrk, if no no CE sinature found
Charley is offline
Old 16-02-2005, 06:01 PM   #6 (permalink)
swatkat's Avatar
anything that is downloaded from Net, is not workin? what about softwares installed or copied from CDs?
Do u have any recent Digit CDs?Copy HijackThis from there....
r all softwares (that r not downloaded from the Net) r working correctly?
swatkat is offline
Old 16-02-2005, 06:26 PM   #7 (permalink)
Just Do It
Let me check it out. I have to search thru the CDs to find it & then let u know...
Tks
Charley is offline
Old 17-02-2005, 08:33 PM   #8 (permalink)
Just Do It
That wasnt the problem..
The exact problem was that in the firewall setting it was enabled to bloack all incoming traffic which resulted in the error.
Now its working fine.
Tks dude
Charley is offline
Old 17-02-2005, 11:33 PM   #9 (permalink)
swatkat's Avatar
wow...strange...thanks for the info...why did u set it block incoming traffic?
swatkat is offline
Old 18-02-2005, 11:45 AM   #10 (permalink)
Just Do It
Lol..
I'd taken the new connect from BSNL---dataone, the guys installed it so wasnt aware of it... got a friend to chck it out..... prob resolvd
Charley is offline
