Old 16-02-2005, 12:23 PM   #1 (permalink)
Just Do It
Default Upgrade P-133mhz/New config upgrd
I have p-133mhz. Is it possible to upgrade the syste, to a new 1.
Incase no, then how much would it cost for a latest config. My budget is abt 10-15k..
Is it possible to get an assembled 1 for that budget...
I'd require a system with webcam, dvd drive, bluetooth device....
Let me know
Tks
Charley is offline
Old 16-02-2005, 12:55 PM   #2 (permalink)
dont think u can get all that within 15k . raise ur budget 2 round 20-25k , n u will b able 2 get ( including web cam .....)
mamba is offline
Old 16-02-2005, 01:31 PM   #3 (permalink)
Just Do It
8)
Wht abt an assembled one........
Where cud i search for each components so i can check it out
Charley is offline
Old 16-02-2005, 01:59 PM   #4 (permalink)
There was a post here about assembling a system in 20K just search for it. but 15k mate is really scratching the barrel. U wont get anything out of it.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 20-02-2005, 12:48 AM   #5 (permalink)
speedyguy's Avatar
friend....itz true u gotta increase ur budget but still u can get a decent cnfg out of 15k....
cpu- around 7k
mb- arnd 3k
cab- 1k
ddr-1k (128 mb stick)
there are others but 1st checkout wats ur present cnfg and apart from these check wat all u need....including hdd, cdroms floppy drives as they wud make u increase ur budget...gud luk
No Pain...No Gain
speedyguy is offline
