Old 14-08-2004, 12:15 AM   #1 (permalink)
Default A little Help required !
My borther was flashing his liteon cd writer with newer firmware/BIOS and when suddenly windows 98 crashed, now the system does not boot up.
It only shows that Americann Megatrends Bios Display and stops there, windows 98 does not start, he tried to reinstall windows 98 but the computer hungs at the Bios so cannot start computer.
did the newer Bios/firmware for the liteon CD writer destroy the mother board bios. I had read that if motherboard bios is spoilled then the motherboard cannot be repaired.
How do I solve this problem,How much cost will come to repair the motherboard
She moves like she dont care...smooth as silk cool as air..!
superwiz is offline
Old 14-08-2004, 12:38 AM   #2 (permalink)
If you have the socketed Bios then you can replace it. But if it is not then I'm sorry my friend, you have to spend some money..
Compaq Presario Notebook, AMD Mobile Sempron 3000+ (1.8 GHz), ATI Mobility Radeon Xpress (PCIe) 200M 128MB Graphics, 768 MB DDR 333 MHz RAM, 40 GB HDD, DVD+CDRW Combo, 15".....
krish is offline
Old 14-08-2004, 12:46 AM   #3 (permalink)
Thank you for replying but can u tell me how much will it take to repair the motherboard if possible, or do I have to buy a new motherboard
superwiz is offline
Old 14-08-2004, 10:07 AM   #4 (permalink)
NikhilVerma's Avatar
Just take out the CD writer and try...
NikhilVerma is offline
Old 14-08-2004, 11:22 AM   #5 (permalink)
Oye, Thank you.I removed the Liteon cd writer and it worked..now the computer is starting up and windows 98 loads ha ha but when we connected the cd writer back it stopped again at the bios screen .
Does this mean the cd writer is faulty?
superwiz is offline
Old 14-08-2004, 01:11 PM   #6 (permalink)
Yeah it seems that you have problem with your cd-writer, which might have happened due to Flashing and Windows crashing all at the same time.
Try Disabling the Drive in the BIOS by selecting the IDE Device in the BIOS and setting to NONE.
Then try to restart.
Also if the FLASH BIOS chip inside the writer is a socket type then you can remove it and get a replacement. Hope your Warranty period is not expired.
All the best .
Kannan.
Binary Bits
http://www.binarybits.net
Kannan is offline
Old 14-08-2004, 03:40 PM   #7 (permalink)
All the best .
warranty is over 4 months back its a liteon 48x24x48x
is there anyway i can cheaply repair it
superwiz is offline
Old 14-08-2004, 07:01 PM   #8 (permalink)
TE God
if you don't mind spending Rs.2600, go for the samsung combo in this month's issue. u can play dvd's too !
anishcool is offline
Old 14-08-2004, 08:40 PM   #9 (permalink)
me 2 wold siggets u the same thng, buy a new drive, repairing the old one is not worth it, mght cost 1000+
Attack life, it\'s going to kill you anyway.
walking-techie is offline
Old 15-08-2004, 12:45 AM   #10 (permalink)
flash ur drive again lol
~Therez a difference between knowing the path and walking the path ~
anusoni is offline
Old 15-08-2004, 12:51 AM   #11 (permalink)
JAK
What the Heck !
JAK's Avatar
well one simple solution....
I had posted a solution a long time ago reg. a similar thing...
http://www.thinkdigit.com/forum/viewtopic.php?t=2733&highlight=firmware
if u hav trouble understandin anything post back here...
Risk more than what others think is safe.
Care more than what others think is caring.
Think more than what others think is thoughtful.
Do more than what others think is possible.
JAK is offline
Old 15-08-2004, 01:41 AM   #12 (permalink)
Oops, I think I think that I gave you the wrong sloution. Sorry for that.
krish is offline
