Old 12-05-2007, 01:01 PM   #1 (permalink)
lalam's Avatar
Default Need an answer fast
Planning to buy a new hard disk and i just happened to find that the current hard disk in my pc is of ATA and not SATA so i wanted to know if this two are compatible or not so like can i still use SATA drive? I'm trying to go for Seagate Baracuda 7200.9 (160 gb) or Seagate Barracuda 7200.10 (320 gb). Would also like to know what are the other specs that i should be looking for, in case i wanted to get a new graphic card and also if there's anymore spec i should be taking a look at for HDD on account of compability for my computer that is. Thanks!
Why isn't anybody answering? Isn't ATA and SATA different? I'm not very familiar with hardwares so......
lalam is offline
Old 12-05-2007, 01:21 PM   #2 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Default Re: Need an answer fast
You will have to check your Motherboard if it support SATA or not. As for graphic card....same thing...check your MOBO if has AGP or PCI-E slot. After that, you can decide what to go for
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 12-05-2007, 01:31 PM   #3 (permalink)
lalam's Avatar
Thanks sukhdeep! Its an AGP slot....
lalam is offline
To get answer suraj QnA (read only) 3 09-12-2006 10:26 AM
answer this????? Binay 007 Gamerz 3 29-11-2006 05:54 AM
Windows Vista Customer Preview Program—RC1 is open now..fast fast ravi_9793 Technology News 19 20-09-2006 11:54 AM
your answer abhinavrakesh Gamerz 3 18-03-2006 11:07 PM
Please Answer............ nipun_the_gr8 QnA (read only) 4 22-04-2005 05:31 PM
