Old 10-05-2007, 07:25 AM   #1 (permalink)
Unhappy Context Menu Problem. Please Help.
I am having a problem with my context menu. generally when you right click on a folder/drive, the context menu show open as the default first action and that is also used when you double left click on a folder/drive. my problem is that when i right click on a folder/drive, it shows Explore as the default first action and its also being used when i double click on a folder/drive. please tell me how to change this back from Explore to Open.
avik_basu is offline
Old 10-05-2007, 01:38 PM   #2 (permalink)
royal's Avatar
Smile Re: Context Menu Problem. Please Help.
I read somewhere a registry hack can do it...maybe VISHAL GUPTA can help you.
royal is offline
Old 10-05-2007, 02:08 PM   #3 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: Context Menu Problem. Please Help.
OK... Try this, (Hoping that you are in WIndows XP)
Go to Folder Option, Then to TAB File Types and navigate to option [NONE] Folder Refer to the screenshot, now Click advance, in the advance Window you may set the default action back to Open or ad any other action if you like
hope this helps...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 10-05-2007, 05:49 PM   #4 (permalink)
royal's Avatar
Wink Re: Context Menu Problem. Please Help.
hope this helps...
Hey that's cool man...
royal is offline
Old 10-05-2007, 10:37 PM   #5 (permalink)
Wandering In Tecno Land
Ecko's Avatar
Thumbs up Context Menu Problem. Please Help.
Use WinXP manager
Born in Windows Die In Linux © 2009-10 All Rights Reserved.
Learn Linux : www.linoob.com (Official WebSite)
Ecko is offline
Old 10-05-2007, 10:55 PM   #6 (permalink)
Rebooting
Originally Posted by gaurav_chd88
Use WinXP manager
please give some details...
rebooting
ChotoCheeta.com
Customize Context Menu ismart QnA (read only) 1 25-03-2007 05:01 PM
missing desktop context menu items GeeNeeYes Software Q&A 4 18-09-2006 10:22 PM
irritating Context menu hansraj QnA (read only) 1 18-03-2005 06:35 PM
Outlook Express Context Menu Tech&ME Software Q&A 2 09-02-2005 10:09 PM
