09-05-2007, 08:00 PM
very very STUPID
will any data loss occur if CD is kept under WATER?
HI GUYS.
CAN U TELL ME WHETHER any data loss occur if CD is kept under WATER?
HOW MANY HOURS CAN A CD BE KEPT UNDER WATER SO THAT NO DATA LOSS OCCURS?
Please Don't Pirate!
09-05-2007, 08:08 PM
Host4Cheap.org
Re: will any data loss occur if CD is kept under WATER?
No loss will occur
http://www.host4cheap.org/
09-05-2007, 08:39 PM
But why are you asking such question ? I hope you are not going to store your cds under ocean
09-05-2007, 09:33 PM
no loss will occur.... but if tht's an indirect question...may be u wanna know how to make data on CDs unrecoverable.. then just do any one of the following: put them in to oven OR move a magnet over them for sometime while watching cartoons... ur data will be lost... HAHAHAHAHA
TechExplorer.in
09-05-2007, 09:40 PM
Asterisk enthusiast
its optical media not magnetic nothing will happen to cd even if you put it over
a power plant dynamo.
btw cd will genrely not be harmed inside the water but it should be distilled as chlorine and other substance in water in water can react with aluminum compound based outer reflective surface to make cd unusable
09-05-2007, 09:44 PM
Mad and Furious
09-05-2007, 10:09 PM
Even humidity does damage CDs over time.
But what exactly is meant by the question?
Quote
"no Harm Under Tap Water!"
But tap water generally contains chlorine which is chemically very reactive.
V.Prem Kumar
09-05-2007, 11:51 PM
water i suppose peels off teh writable layer..ie teh silver parrt.
09-05-2007, 11:54 PM
gooby pls
Originally Posted by kerthivasan
HI GUYS.
No
09-05-2007, 11:55 PM
Rebooting
Plastic is a very good water proof stuff, therefore, when going under water put cds in a plastic pack  that will make sure no contact with water
rebooting
ChotoCheeta.com
Alive Again...
No data loss
but like every one has to die
same every CD will automatically damage when its time come
10-05-2007, 06:33 PM
Mad and Furious
What I mean to say is, once I had tried it with my CD's. I washed them out of their dirt under tap-water, and no data loss occurred.....
10-05-2007, 09:27 PM
The Researcher
why don't you try it yourself? Post your results here.
10-05-2007, 09:54 PM
Asterisk enthusiast
Originally Posted by Ramakrishnan
Plastic is a very good water proof stuff, therefore, when going under water put cds in a plastic pack that will make sure no contact with water .
agreed the cd is made of plastic but the recording and reflectative surfaces are made of aliminium compounds which melts in the burning processos to make dents which are identical to pits of stamped CD now this cotaing can react with chlorine and other reactative substances in water and corrode making cd use less in some time if kept under water.
he is talking about keeping cd inside the water for extended period of time not
washing as its done only for a min or two.
10-05-2007, 10:38 PM
Host4Cheap.org
All i can say in the end. what a useless discussion. We all have something better to do IMHO
10-05-2007, 10:43 PM
Exactly.
V.Prem Kumar
10-05-2007, 10:52 PM
Why mods allowed this thread still running
11-05-2007, 12:17 AM
Because every ( techy )Geek (including me ) have not posted a reply here yet.
LOL.
11-05-2007, 12:24 AM
#19 (permalink)
Rebooting
sorry to pat my nose in, but may i ask whats wrong in this thread ?? Personally I dont see ahy violation of rule  ... do u see any ??
@abhasbajpai
 U quoted me with the name of some one else
rebooting
ChotoCheeta.com
11-05-2007, 12:29 AM
#20 (permalink)
Microsoft MVP
CD might get cold.
jokes apart, no data loss will occur... In fact I wash old CDs sometimes to make them working.  Even I hv used tooth-pastes a few times to fill the scratches...
11-05-2007, 12:34 AM
#21 (permalink)
String Phreak
5 years ago I heard a rumour that if the cd gets a lotta oil on it surface and the cdrom is unable to read it, then just wash it with shampoo!
I washed it with shampoo, and wonders.....the cd worked again!
So afaik "data loss wont occur if CD is kept under WATER"!
11-05-2007, 12:45 AM
#22 (permalink)
I suspect this can gonna be the largest thread. Mod dont close it please.
LOL.
11-05-2007, 12:48 AM
#23 (permalink)
Rebooting
Originally Posted by Vishal Gupta
CD might get cold.
woak...
get a patent
who used this method 1st
rebooting
ChotoCheeta.com
11-05-2007, 01:08 AM
#24 (permalink)
Microsoft MVP
^^ yes, it works. try it.
11-05-2007, 08:14 AM
#25 (permalink)
This is what is called home remedy!
V.Prem Kumar
11-05-2007, 12:56 PM
#26 (permalink)
Asterisk enthusiast
you may have done this on lower plastic part from which lens picks up and read
have you tried this on the top coated part of the cd (which is the reflective coating) if you put a CD in front of a light source and and you can see the light passing through the pores made by scratches or corrosion you cannot repair or use that cd normally (off course there are technics to repair those that but are beyond home users and only work for 40% of the cases)
11-05-2007, 02:24 PM
#27 (permalink)
C# Be Sharp !
although CD is made ot of plastic bout outer(aka data) layer is not exactly plastic , so technically it can get affected if kept under water for prolonged periods ?
CD might get cold.
 , same here i normally use toothpaste or any soft(pH~7) soap to wash CD's . u can also wash your cd's with Milk as it decreases surface tension of Surface to extremely low levels thus u can wash out dust n other minute particles if ur cd's is badly scratched .
There are 10 types of people in the world: those who understand binary and those who do not.
11-05-2007, 04:14 PM
#28 (permalink)
Host4Cheap.org
11-05-2007, 07:33 PM
#29 (permalink)
Then why not add Harpic and Aquaregia (Nitric+Hydrochloric acids) to the list.
Any of them will instantly destroy any dirt, dust or bacteria!
V.Prem Kumar
Search this Thread |
