Well, you cant really say for sure that its not the graphics card, because the problem doesnt seem to kick in until he loads a game. And if you remember, a lot of the core components of the card are not called to work until you actually load a game. So while Windows in normal working mode may work fine, if its a glitch on the card, it probably wont show up until the gaming specific components are put to the task. The only way we can know for sure is to plug another video card in. Of course, I hope to God that I am wrong, because if it does turn out to be thermal damage, he's pretty much out of luck and has to shell out dough for a newer card.
Playing FEAR XP/LSW2
