09-05-2007, 12:09 PM
Cool as a CUCUMBAR ! ! !
C drive dead ! ! !
i have formatted my c drive bt it seems 2 b dead ........ its not installing new OS : XP ......
is my data on d e f g h safe ?
how can i retrive it ?
09-05-2007, 12:15 PM
In search of light...
Re: C drive dead ! ! !
if you have a FAT32 partition (if possible try to format C:\ as FAT32), try using a live CD like Knoppix to retrieve the data.
http://abhijeetdeb.com
09-05-2007, 12:48 PM
Host4Cheap.org
Yes, your data should be safe on other drivers.
What problem u face while installing XP on C ??
http://www.host4cheap.org/
09-05-2007, 12:59 PM
what error do u get.
yes ur data shld b safe
do as abhi said otherwise, connect ur harddisk to ur friends pc n copy all the dat to his harddisk for time being
To handle yourself, use your head; to handle others, use your heart.
09-05-2007, 01:04 PM
i guess it konkked off ......... its dead i think .........
09-05-2007, 01:07 PM
Rebooting
u are not clear
if the HDD is not getting detected at Bios then alarm  data on any drive is at risk...
what happens when u try to install XP ?? please be clear !!
rebooting
ChotoCheeta.com
09-05-2007, 01:10 PM
1337 |)00|) \m/
How does a partition seem to be dead? Is XP not getting installed at all ? what is happening when you boot using the install disc ? Any particular error ? Hangs ?
^^^ Above suggestion seems good.... I'd too suggest it. But, it'd be good if we can identify the problem and fix it....
My Blog : www.vatsuak.blogspot.com
My DA page : www.burningsilver.deviantart.com
OK..ok..... Ads are bad.. ;)
09-05-2007, 01:42 PM
Search for Adventure
U r very confusing - pls try to explain wht exactly happening, don't guess anything.
bad sectors may prevent u to install xp on c, but it can't be "dead"
Nobody is Perfect. I am "Nobody"
09-05-2007, 02:20 PM
Rebooting
imfact whats the term mean by dead ?? as a partition cant be called dead yes a HDD can.. but what really is DEAD
rebooting
ChotoCheeta.com
09-05-2007, 06:09 PM
Best option is to take out your hard drive and connect it to your frnd's computer (by setting it in slave ).
Check there and you should be able to retrieve the data you want..
BTW what do you mean by "dead" hard-drive
Everything is Possible
09-05-2007, 07:07 PM
"The Gentleman"
and can u b clear how to recover the data it might help others also...
"The use of COBOL cripples the mind; its teaching should, therefore, be regarded as a criminal offense."
- Dijkstra
09-05-2007, 08:17 PM
just copy paste the files/folders you want to recover onto the FAT32 drive., i suggested Knoppix because Ubuntu does not mount the drives while working with a Live CD.
09-05-2007, 10:33 PM
"The Gentleman"
in knoppix i tried to copy one file from one folder to another folder/drive but it does not copy... but the file gets copied to knoppix desktop... how to copy file from one drive to another drive????
- Dijkstra
09-05-2007, 11:54 PM
^is the drive you're trying to copy onto a FAT32 formatted drive. it cannot write in a NTFS formatted drive.
10-05-2007, 12:05 AM
"The Gentleman"
i tried on both fat and ntfs didnt work on both
- Dijkstra
10-05-2007, 12:21 AM
Gangsta
Location: I come from the land of WARRIORS, land of 5 rivers, where the alcohol will make your liver quiver!!
It Did Happen to me also ,
10-05-2007, 12:26 AM
Gangsta
and one day my hole drive become dead !!!!!!!,after checking it i found a burn on the back side so there is so replacement for this ,,,,,,,,,thats wat happened to me dude so just be sure and see that if there is any prob with your hardware ok.............
Reason: Automerged Doublepost
10-05-2007, 01:22 PM
@cooldip10 ....... did the same way u have described ........ & it did work ......
have 2 buy a new 1 .........
DEAD is my c partition ....... even tried 2 transfer some files from my frds hdd 2 c, wont copy & format 2 ....
guess 2 many BAD sectors .............
10-05-2007, 05:21 PM
#19 (permalink)
Thanx buddy for trying my way.
BTW were you able to retrieve your data?
Well get your self a good SATA hard-Drive if your mobo permits.
11-05-2007, 12:40 PM
#20 (permalink)
if u want 2 transfer ur data from 1 hdd 2 another try using " norton ghost " to transfer, it will do the job in minimum time.
17-05-2007, 04:46 PM
#21 (permalink)
@cooldip10 ........ no SATTA bt ATTA is supported ..........
@ITTechPerson ........... norton ghost is a fantastic idea bt i dont have afull version, do u ?
17-05-2007, 05:58 PM
#22 (permalink)
sorry boss, I do have only a trail 1, let me see if I can arrange 1 full
Search this Thread |
