Old 09-05-2007, 11:27 AM   #1 (permalink)
cooldip10's Avatar
Exclamation Sata + IDE = Will it work? + DVD RW suggestion.
Hi guys..
1)I wanted to know whether it is possible to run a SATA hard-drive and IDE DVD/CD read-write device simultabeously on same mobo..
I am actually to buy a new mobo but after sometime. But I urgently need to have a DVD RW. SO IDE is the only option for me.. Then if I switch to the new system will there be place for IDE with SATA ports?
2)Also I found Sony DRU170C as a suggestion from my friend.. Any other choice to buy a DVD RW?
Everything is Possible
cooldip10 is offline
Old 09-05-2007, 11:33 AM   #2 (permalink)
Cool G5's Avatar
Lightbulb Re: Sata + IDE = Will it work? + DVD RW suggestion.
Liteon LH-20A1P.
After some months Ide will be replaced by sata,but it's still a long time to go.
Cool G5 is offline
Old 10-05-2007, 09:43 AM   #3 (permalink)
cooldip10's Avatar
Default Re: Sata + IDE = Will it work? + DVD RW suggestion.
The question is still on.. More views invited.
@Cool G5: Will both work on same mobo? <<my main question is this..
I am still waiting.
Old 10-05-2007, 11:14 AM   #4 (permalink)
thetopcyborg's Avatar
ya i guess both will work as the new mobos have not completely abandoned IDE. So you can n\connect ur HDD to SATA and DVD-RW to IDE.
thetopcyborg is offline
Old 10-05-2007, 11:36 AM   #5 (permalink)
Cool G5's Avatar
Thumbs up Re: Sata + IDE = Will it work? + DVD RW suggestion.
Ya surely both will work.As said above new mobo still have IDE.
Cool G5 is offline
Old 10-05-2007, 02:14 PM   #6 (permalink)
Thor's Avatar
WILL WORK!
I have
a Sata Seagate HDD 80 GB
a IDE Seagate HDD 80 GB > Primary Master
a IDE Sone DVD Writer > Secondary Master
Works Like a Charm..
All the best.
Beware of my Wrath Mortals, Thou hast no choice.
Thor is offline
Old 10-05-2007, 05:17 PM   #7 (permalink)
cooldip10's Avatar
Originally Posted by Thor
WILL WORK!
I have
a IDE Sony DVD Writer > Secondary Master
All the best.
1)Is there really no problem in running both hard disks simultaneously?
2)Which sony DVD writer are you using ?
Old 10-05-2007, 08:58 PM   #8 (permalink)
Thor's Avatar
Really there is no problem...
I hv also used Two IDE Hdds
1 as Primary Master
and the other as Secondary Master.
While I had a CD-Writer and used that as Primary Slave.
Then also it worked like a charm! That was my old machine
Now that I hv said abt my new rig...
Only thing taken into account is ur SMPS must be capable of supplying power to an Xtra 2nd HDD ... in most cases newer SMPS have a rating oif 400+ Watts.. so no problem shud be there
My DVD Writer is :
SONY DVD RW DW-Q30A ...
Thor is offline
Old 11-05-2007, 12:54 AM   #9 (permalink)
crazydevil's Avatar
yes both will work.... i am using in that manner
go for sony DRU 820
crazydevil is offline
SATA ROCKS : Fujitsu intros first 2.5" 7200 rpm hard drive with SATA 2.5 interface techtronic Technology News 7 22-03-2009 11:09 PM
Sata-II hard disk working at Sata-I mode Arsenal_Gunners Hardware Q&A 27 17-03-2009 10:18 PM
Can I attach a new sata drive to my existing Seagate 80GB SATA HDD? praka123 Hardware Q&A 6 04-02-2007 06:28 PM
How to connect SATA HDD to a mobo w/o SATA port ashnik Hardware Q&A 7 31-03-2006 08:52 PM
wats better Hitachi(SATA) 80gb or Samsung(Sata)80gb ??? King_Niral QnA (read only) 12 14-08-2005 05:11 PM
