Hi guys.
I use WinXP Pro SP2 with latest updates installed.
I'm facing very strange problem.
I used a software called RockXP which is basically a Windows XP Key Changer.
I used it change my Windows XP key 2 times.
Now, there are 2 entries in my registry in the following location:
HKEY_LOCAL_MACHINE\SYSTEM\WPA\
Key-3HFYCVKFXVR6VJM823DM9
Key-CJ27J3P2XV9J9JCPB4DVT
Key-JTQKT68H63DJ9BCJV4YK4
One of them is the one that was created while installing Windows. The rest 2 by using the software.
Now, because of them my system hangs a few times & takes a lot of time while scanning for Automatic Updates.
So, I tried deleting them (bold ones). But the problem is, they're not getting deleted.
I get a warning saying: Error deleting key.
There is no option in that software to delete those keys.
I'm the admin of my system.
Is there any way to delete these registry keys/entries?
