Old 08-05-2007, 10:59 PM   #1 (permalink)
Unhappy Urgent help needed for Tata indicom problem
hi everyone
I want to use my tata indicom walky set for internet but i dont have the driver cd. plz tell me how can i setup my phone for my use without using driver cd (Model is LG lsp 345). is it possible? plzzzzzz help me its urgent.
sushantsaurabh is offline
Old 08-05-2007, 11:31 PM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default Re: Urgent help needed for Tata indicom problem
It depends upon the type of data cable. If ur data cable is serial one, then u don't need the driver CD. But if u hv USB cable, then u'll need the driver CD.
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 08-05-2007, 11:42 PM   #3 (permalink)
Rebooting
Choto Cheeta's Avatar
try this, it may help...
http://www.tataindicom.com/t-persona...ad-dialer.aspx
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 08-05-2007, 11:50 PM   #4 (permalink)
I Have Serial Cable Plz Help.
I HAVE SERIAL CABLE PLZ HELP BUDDY.
Last edited by sushantsaurabh; 08-05-2007 at 11:50 PM. Reason: Automerged Doublepost
Old 09-05-2007, 03:14 AM   #5 (permalink)
Microsoft MVP
A. First u'll hv to install modem for ur phone:
1. Open Control panel and start "Add New Hardware" wizard.
2. Now select to manually install the driver.
3. Now select "Modems" from list and click NEXT.
4. Now enable the option "Don't detect my modem, I'll select it from list".
5. Now select "Standard 19200 bps Modem" from list and click NEXT.
6. Select the Serial COM post from the list and it'll install the modem.
7. After installing modem, open "Device manager" and double-click on the installed modem and in "Advanced" tab, add following string in "Extra initialization commands":
AT+CRM=1;$LGPKT=3
B. Now u hv to create an internet connection for it:
1. U can create a new connection either using "Network connection" or using IE Options.
2. Use #777 as phone no and internet as username and password. (both are same and case-sensitive.)
Thats it, now just connect ur phone and dial the connection w/o any problem.
Old 09-05-2007, 12:15 PM   #6 (permalink)
Rebooting
have u guyess considered the link which i gave ????
rebooting
ChotoCheeta.com
Old 09-05-2007, 04:43 PM   #7 (permalink)
sorry dear cheeta I cant download this because right now I m just using the through cafe. & thax to vishal
tata indicom internet outlaw Mobiles and Tablets 5 11-11-2006 07:32 AM
Tata Indicom (help) Chirag QnA (read only) 7 19-09-2005 12:17 PM
Tata indicom users vishal_bhatia87 QnA (read only) 4 17-05-2005 03:49 PM
