Old 08-05-2007, 07:52 PM   #1 (permalink)
Unhappy how to run .bin file
Hi frnds,
I've NFS mostwanted which is of 3.6GB having .mdf extension.
Then i mount it in alcohole in which dere were not any executable file
but some .bin files(each one is of 650,700,950 MB).
How 'll i install d game in my PC
PLZ HELP......
Thanx in advance.....
manas_unlimited is offline
Old 08-05-2007, 07:59 PM   #2 (permalink)
Back to l33ching :)
gauravakaasid's Avatar
Location: Latitude: 22° 32' North. Longitude: 88° 22' East
Default Re: how to run .bin file
questions related to piracy not allowed here. Read the Forum rules. Thread Reported.
Whenever you find yourself on the side of the majority, it is time to pause and reflect ~ Mark Twain
gauravakaasid is offline
Old 08-05-2007, 08:06 PM   #3 (permalink)
1337 |)00|) \m/
kaustav_geek's Avatar
True. However, I don't think .bin files run in Windows as they do in GNU/Linux.
My Blog : www.vatsuak.blogspot.com
My DA page : www.burningsilver.deviantart.com
OK..ok..... Ads are bad.. ;)
kaustav_geek is offline
Old 08-05-2007, 09:06 PM   #4 (permalink)
Download Magic ISO or Ultra ISO for extract .bin file.
http://www.miraclesoftware.in
Authorized Software Distributor - Online Software Shopping
boosters is offline
Old 08-05-2007, 10:02 PM   #5 (permalink)
Lean mean A@# kickin M/C
apoorv.sharma's Avatar
dude, if the file is of .msi extension, why dun u try double clickin it!...should install itself on it own!...i think....
It's hard to soar like an eagle when you're working with turkeys!
apoorv.sharma is offline
Old 08-05-2007, 10:04 PM   #6 (permalink)
Burning Bright
anantkhaitan's Avatar
I don't know abt M$ but if it is GNU/Linux u will have to allow the file to execute
For Gnome : Right Click>Permissions : Enable executing the file.. thats it
For KDE : Similar
..::Fedora ::.. Freedom + Infinity + Speech
Registered Linux User #447318
GNUger was here.... Grrr....
Maah! Blog
http://brightedges.blogspot.com/
anantkhaitan is offline
Old 08-05-2007, 11:49 PM   #7 (permalink)
The Researcher
Smile Re: how to run .bin file
Yeah. Double click and it will install by itself
Ramakrishnan is offline
Old 09-05-2007, 12:44 AM   #8 (permalink)
sorry frnds d file was of .mdf extention
After i mount it in alcohole i got .bin files....
wat 2 do den plz help ....sorry 4 d mistake
btw thanx 4 all ur response guys....
Old 09-05-2007, 12:14 PM   #9 (permalink)
I think .bin files can be extracted using an excellent software called isobuster.
maindola is offline
REG file ?? Projjwal Software Q&A 2 20-01-2007 11:53 PM
i have a 2o mb rar file which becomes a 2gb iso file.how do i do it with other stuff? tango_cash Software Q&A 8 27-12-2006 10:47 PM
Change File size in MB instead of GB in properties of a File rachitar QnA (read only) 4 24-11-2005 09:46 AM
How to convert a VDV (*.vob) file in to VCD (*.dat) file Choto Cheeta QnA (read only) 2 17-09-2004 01:47 AM
