Old 08-05-2007, 04:21 PM   #1 (permalink)
Console Junkie
aditya.shevade's Avatar
Default How to create (design) a blog?
Hi
I am designing a website. A personal website. I might think of getting a domain name and host it somewhere. In that case, instead of having a blog on say blogger or wordpress or such services, what can I do to create a blog of my own, blended with my site and it's layout (css)?
In simple words, I want to create a blog like page on my website and how do I do it? There are many sites which have their own blogs, and I think blogger supports hosting on other servers, but what if I just want to start all from the scratch?
Aditya
--- Console Junkie
aditya.shevade is offline
Old 08-05-2007, 04:42 PM   #2 (permalink)
1337 |)00|) \m/
kaustav_geek's Avatar
Default Re: How to create (design) a blog?
Get(download) Wordpress and upload it on your domain. You can customise the code as much as you want later.
I think modding on a predesigned template will be better, since you need to just take care of modding(and posting ,ofcourse) and not the rudimentary part.
In case your objective is learning.. Then, search-up the various Wordpress templates and study their code and the standards they follow.
My Blog : www.vatsuak.blogspot.com
My DA page : www.burningsilver.deviantart.com
OK..ok..... Ads are bad.. ;)
kaustav_geek is offline
Old 08-05-2007, 04:59 PM   #3 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Sure, you can customize the blog. Thats one benefit of self hosted blogs and not with free blog hosters like blogger.com
You can install Wordpress yourself easily, or if your host has something like Fantastico or Installatron you can install Wordpress with a few clicks
You can know more about making themes of wordpress here
http://codex.wordpress.org/Blog_Design_and_Layout
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 08-05-2007, 05:14 PM   #4 (permalink)
1337 |)00|) \m/
Blogger Blogs can also be customised.
Old 08-05-2007, 05:32 PM   #5 (permalink)
Host4Cheap.org
*cough* When i refer to word Customize, i mean you cannot install custom plugins, edit files,install new themes - not templates etc. Got me now *dude*
Old 08-05-2007, 06:43 PM   #6 (permalink)
1337 |)00|) \m/
You can install any JavaScript based plugin on a Blogger blog too. I don't quite understand, what you refer to as a theme. Since, most of the blog is basically a template.
Blogger blogs are quite customisable from most fronts. However, anything Opensource allows endless possibilities for customisation. Hence, WordPress is definitely superior when it comes to the domain hosted blogs.
I'm not quite against Wordpress, I'm just defending the blogger platform.
Old 08-05-2007, 06:51 PM   #7 (permalink)
Salieri Family
hard_rock's Avatar
Location: Somewhere in Internet.......Have dynamic IP address
@aditya.shevade:
All you have to do is install Wordpress and Either you can customize the template or theme of your site to blend with Wordpress or Vice versa...
Another simpler option if you dont want to mess with Template edits is.. You can create PAGES in wordpress which is far more easier..
Wordpress has got many plugins which you can use to edit or customize your site to maximum extent... If you need further help post here..
A person who wants everything in his life... May end up with nothing at all
-Tommy[Mafia]
hard_rock is offline
Old 08-05-2007, 07:44 PM   #8 (permalink)
Console Junkie
Thanks for the help, and I will ask if I need anything else, right here.
--- Console Junkie
Old 09-05-2007, 10:01 AM   #9 (permalink)
Host4Cheap.org
Well you cannot install themes like this on Blogger, can you
http://themes.wordpress.net/
I have never messed much with Blogger, but care to share which all plugins we can install on Blogger and how
Old 09-05-2007, 04:16 PM   #10 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
go 2 http://www.blogspot.com/ .............
ax3 is offline
Old 10-05-2007, 03:29 AM   #11 (permalink)
hi,
i m interested to get a copyf worldspace.
can anyone help?
mobileman
mobileman is offline
Old 10-05-2007, 09:42 AM   #12 (permalink)
Console Junkie
world space? or wordpress? Get wordpress at Wordpress. Get it and unpack it. You will need mysql... and to host it you will need a server....
My advice, get lampp at Xampp
Aditya
--- Console Junkie
SUGGESTION: Best Blog Site for Starting a Blog Vishal Gupta QnA (read only) 43 20-09-2007 08:59 PM
Web Design koolbluez Software Q&A 7 16-04-2007 05:13 PM
Web design ! ! ! ax3 QnA (read only) 5 05-09-2006 03:46 PM
CAD/CAM DESIGN Alive_Hunter QnA (read only) 8 18-09-2005 12:55 PM
