Ok ...i have been experimenting with my firewalls
First i tryed Sygate but it probabaly Deleted my connection...so had to format my machine .Then i used Armor to net nice lill firewall but lacked the punch ...so swithced to Kaspersky Antihacker ..but all it did is report some Helkern Attack ...so Switched to Mcafee Personal ...n tell u what gr8 soft ..not only it protects u but also can track any one who pings you.....
then i shifted to Zonealarm...and really loved it....but the problem is now and then it pops up saying user/Port blocked ...if the no goes to 3-4 per day than its Ok..but i get around 20-30 such messages ....so my q is are all the Hackers in the World Dying to Hack my Comp ...or Zone alarm is just faking it ???
and if not...then what will you suggest is Better Zone Alarm or Mcafee ...
i have a old sys ..so cud not dare to use a Norton product....
