Old 07-05-2007, 02:00 PM   #1 (permalink)
Question (Making a school website)Help Needed?
I recently got the oppertunity to build my school wesite
So i need help regarding this--NO IDEA
-Software is going to be provided by school.
I have suggested
Microsoft web Expressions
I also want to enter this type of forum section to the website.
since this website fourm is powered by v-bulletin which is paid.
Does any free service of this kind exisists.
and the steps to integrate them in website.
Bhuvanmittal420 is offline
Old 07-05-2007, 02:45 PM   #2 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Default Re: (Making a school website)Help Needed?
Do you mean free forum script ??
If yes, then sure...you can try phpBB, SMF, MyBB etc.
Integrating with Website - hmm i did get it properly. You can easily link the website to the forum in HTML. If you want latest posts and stuff to be listed on the main Website - you can do that aswell using the various Modifications available for phpbb
Hope that helps a little
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 07-05-2007, 04:03 PM   #3 (permalink)
u can do it ur self it is easy even i did that on my site www.desi-tek.com
eh wait a min how u will use php with asp.net (session)? u need to use asp.net based forum than only u will be able to integrate it with site.
Dhiraj Thakur
thakur.dheeraj(@)gmail.com
Desi-Tek.com is offline
Old 07-05-2007, 04:59 PM   #4 (permalink)
php with asp.net session @#@$
Old 07-05-2007, 05:00 PM   #5 (permalink)
Host4Cheap.org
SAME here
Old 07-05-2007, 05:03 PM   #6 (permalink)
asp.net session
could you explain a
little more
Making a website, help plz utsavfrom2007 QnA (read only) 11 05-02-2007 10:25 AM
Help needed in making a pc in the range of 35-36k shikhar_kapoor143 Hardware Q&A 6 19-05-2006 10:57 AM
which website making tool mohnishghodekar QnA (read only) 11 09-04-2006 05:19 AM
