Old 14-02-2005, 09:42 PM   #1 (permalink)
Default CD WRITER
Hi ppl
I have this problem...
I got a cd witer with my HP PC... and off late when I burn things using Nero ( The latest version )... and run a cd-verification, it says error reading sector.. this happens with CD-R and CD-RW...
The files dont execute...
HELP !!!
abhinav_g90 is offline
Old 16-02-2005, 02:57 AM   #2 (permalink)
Laptoping
Sourabh's Avatar
try turning off some system hungry stuff
use some good CD-R , CD-RW media
try copying a cd once to check whether ur writer is working fine r not
Sourabh is offline
Old 17-02-2005, 05:23 PM   #3 (permalink)
Could be bad cable.. OR it could be the other drive you have connected to the same cable is causing problems. Do you have anothe drive or cdrom connected as a slave to the same cable? I have had this weird corruption problems with bad cables or having my LG drive as a slave with a DVD-ROM drive as master.. But switching the drive as a master fixed the problem. (actually took it back to the shop and had to be embarsed when they connected it and it worked fine).
AlienTech is offline
Old 19-02-2005, 01:14 AM   #4 (permalink)
Probably you are burning at a very fast speed and using not so good quality media .
AMD64 2800+ 1GB ECC DDR 400 ,MSI K8T800 Asus Geforce FX 5200 128 MB, 120 GB Barracuda,16X DVD RW,Samsung 16x DVD,Samsung Wireless ,Creative AUDIGY2 ZS 7.1 with Creative Inspire 7.1/1800+AXP 512MB ECC DDR400 .40GB BLACK
indro is offline
Old 19-02-2005, 01:46 AM   #5 (permalink)
swatkat's Avatar
1]Always burn atleast 4X speed lesser than the CD media supports.
2]Enable DMA both for HDD and CD Writer.
3]Update the ASPI layer.
http://www.adaptec.com/worldwide/sup...71.exe&sess=no
http://swatrant.blogspot.com/
swatkat is offline
Old 19-02-2005, 05:06 AM   #6 (permalink)
enoonmai's Avatar
In addition to all that swatkat has suggested, I also suggest you make sure you check the "Verify written data" while the burn process is executing. If the process fails, its most likely the media at fault. Get a known good media, preferably none of that 12 buck stuff that seems to be doing the rounds these days.
Playing FEAR XP/LSW2
enoonmai is offline
- by tv6952
- by soumya
