Old 14-02-2005, 06:52 PM   #1 (permalink)
Default Slipstreaming doubt
i have an original windows xp sp1 cd bootable i just wondered after slipstreaming will i have to activate windows again since i can activate my windows only three times and i format my system a lot
shriekers is offline
Old 14-02-2005, 07:48 PM   #2 (permalink)
i think ur a bit confused
slip streaming is adding a service pack to the OS installation cd
if ur talkin abt upgrading to the sp2 ... then thats not slipstreaming
and no u dun have to reactivate
theraven is offline
Old 14-02-2005, 11:06 PM   #3 (permalink)
what i mean when i install my xp i have to activat6e it will i have to activate it after slipstreaming it
Old 15-02-2005, 12:51 AM   #4 (permalink)
ARRGHHH
DUDEEE
what are u talkin abt ?
slipstreaming ur xp os cd ? or installin sp2 on ur computer ???
if ur talkin abt "SLIP STREAMIN" then it means integrating sp2 with ur windows cd
if ur talkin abt just installin then thats NOT called slipstreaming
if ur talkin abt slipstreaming .. then why would u need to reactivate ?
unless u need to reinstall
if ur talkin abt upgrading ... THEN NO u dun have to reactivate
theraven is offline
Old 15-02-2005, 03:35 PM   #5 (permalink)
QA Juggler
saROMan's Avatar
bro...when you Splitstream your Xp CD then you get a new CD of XP with SP2 ..so untill you install XP from this new CD ....you cant Activate it..got it??
8-) सारोमान :!: :!: :!:
saROMan is offline
Old 15-02-2005, 04:58 PM   #6 (permalink)
I agree i want to slipstream it.
What i mean is that if i try to install the new C.D. after formatting my system do i have to activate my windows like my original cd
Old 15-02-2005, 09:36 PM   #7 (permalink)
yes you will !
theraven is offline
Old 15-02-2005, 10:08 PM   #8 (permalink)
Fresh Stock Since 2005
Why do you have to activate your windows anyway?? I have a pirated version and i slipstreamed successfully. I have installed SP2. But what will happen if I would like to repair my XP system. Will SP2 still be there??
khattam_ is offline
Old 15-02-2005, 10:57 PM   #9 (permalink)
Firstly he has a genuine copy so comparing & giving a alternative is ridiculous.Depending upon how windows activation works & what hardware changes are made to the system he may need to activate windows.
For your second part,yes.
www.Oobertech.net
digen is offline
Old 16-02-2005, 01:33 AM   #10 (permalink)
dont u learn dude ?
admittin openly u use a pirated copy of windows just creates hatred for u
ur just inviting flames ... if thats what u want go ahead ..
and stop giving ridiculous advice to people with genuine problems
theraven is offline
Old 04-03-2005, 05:38 AM   #11 (permalink)
Windows activation file can be saved for future installations. One third party software supports this, i think it is XP manager and hope this is not illegal.
khattam_ is offline
Old 04-03-2005, 02:31 PM   #12 (permalink)
enoonmai's Avatar
You don't really a third party software. Just backup wpa.dbl and wpabackup from the Windows/System32 directory and provided there are no major hardware changes when you reinstall XP, you can just boot into the Safe Mode, and then copy these files back in after renaming and moving the existing files.
Playing FEAR XP/LSW2
enoonmai is offline
