Old 06-05-2007, 10:43 AM   #1 (permalink)
Default Strange prob.
Hi ,
I hav a strange prob.. I hav a bsnl broadband connection.I hav 2 pcs , Its works fine with 1 pc but with other link ( LED) repesdly vanishes and net disconnects . Mind it i hav tried both Pcs frm same ADSL line and port..
My PC is Windows XP sp2, D915GAV, Like Link breaks after5-10 mins of connection , y this is happening?? nd its nt a virus or stuff coz i scanned my pc thoroghly
navisangha is offline
Old 06-05-2007, 12:10 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: Strange prob.
You have no control over Link, though make sure the set up of Spliter is right.. i mean the main telephone line will come in to spliter then u will distribute that to Phone Hand set and modem, make sure there is no hand set is connected to the line before Spliter... if the problem still happens, it is at ISP end, complain to Local exchange, problem is suppose to be solved by Area Broadband team of your local exchange... (Contact D.E. Int of your exchange)...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 06-05-2007, 11:46 PM   #3 (permalink)
nai u didnt get it..The line is perfect coz if connect tha modem on same line but to another pc/laptop it works fine ..But it behaves irratically with this pc...
So wat could be the prob in pc that may lead to loss of link.
Old 07-05-2007, 12:31 AM   #4 (permalink)
Rebooting
Did you try changing the interface ?? I mean try switching to USB if you are running LAN or to LAN if you are running USB !!
rebooting
ChotoCheeta.com
Old 07-05-2007, 09:56 AM   #5 (permalink)
a_g = JPKN
s18000rpm's Avatar
are the IP, DNS..... settings same in both PC's?
& try changing the Modulation Mode in modem settings page.
btw are you using a dialer?
ASUS K53SV SX520D + BF3
s18000rpm is offline
Old 07-05-2007, 10:07 AM   #6 (permalink)
Super Saiyan
Goten's Avatar
Check ur ip n DNS settings.
Error seemd to be in that.
Peace~~~!
Goten is offline
Old 07-05-2007, 01:45 PM   #7 (permalink)
Ishan's Avatar
I a having the same problem...with some diff....
in my Pc if i dont browse for some time and then try to open a site it behaves like as if there is no internet connection...but when i turn off and then on them modem switch wait for the link and then browse..everything goes fine....but in Laptop that doesnt occur
the difference is Link is always there with red light still not able to browse but have to turn off/on the modem..
I understand ur problem navisangha
When was the last time when you did something for the first time?
So many words for the broken heart.....
for world wars. ishangajera.blogspot.com
Ishan is offline
Old 20-05-2007, 02:04 PM   #8 (permalink)
sorry for opening old thread again.. settings r same .. but it just doesnt work..
plz help
how do i connect broadband on win2000 as it has no connection option for broadband
strange prob.. abhishekkalra Software Q&A 2 12-08-2006 04:08 PM
strange prob with the PC ??? cozimbond QnA (read only) 9 23-12-2005 10:55 PM
Strange software prob..plz help Terahertz Software Q&A 10 09-09-2005 01:14 PM
Strange prob: plz help dOm1naTOr QnA (read only) 9 26-07-2005 04:54 PM
strange prob!!!help req krisjr QnA (read only) 15 24-03-2005 01:17 AM
