Old 05-05-2007, 11:10 PM   #1 (permalink)
Anindya's Avatar
Angry Being attacked constantly!
For the last two days whenever i am getting online i am being attacked from a computer! I am getting to know this coz the antivirus is showing an alarming msg and the ip address too. I use Avast. Should i do something or leave it to avast as it is doing the job well?
www.techani.com
Latest post ->Take Ur Applications & Personal Settings With You
->Umpires Are Vampires
The Most Unknolegeble Parson. Plese Tech Me.
Anindya is offline
Old 06-05-2007, 12:22 AM   #2 (permalink)
Back to l33ching :)
gauravakaasid's Avatar
Location: Latitude: 22° 32' North. Longitude: 88° 22' East
Default Re: Being attacked constantly!
nope, avast is doing its job alright. make sure u keep it updated. also install a good firewall like jetico/comodo/zonealarm. ur pc will be better secured.
Whenever you find yourself on the side of the majority, it is time to pause and reflect ~ Mark Twain
gauravakaasid is offline
Old 06-05-2007, 01:08 AM   #3 (permalink)
TechTin.com
ravi_9793's Avatar
just ban that Ip address using ur firewall
ravi_9793 is offline
Old 06-05-2007, 10:13 AM   #4 (permalink)
Back to l33ching :)
@Anindya....are u using Alliance cable connection and on a LAN? if u r, then u can report this to the Alliance customer care.
Old 06-05-2007, 11:43 PM   #5 (permalink)
Anindya's Avatar
Talking Re: Being attacked constantly!
I am using Cellone unlimitted GPRS. Thanks i am installing Zonealarm. Thanks to both of u.
www.techani.com
Anindya is offline
Old 06-05-2007, 11:49 PM   #6 (permalink)
Back to l33ching :)
^^no problemo!
Old 08-05-2007, 05:16 PM   #7 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
just block that ip ............
ax3 is offline
MS Office Tips - Constantly updated amrit1 Tutorials 2 31-07-2007 09:31 AM
Help! My system has Been attacked by Adware (i think so) DAVIS Software Q&A 4 07-04-2007 10:43 PM
IE Attacked ---new way --- ketanbodas Software Q&A 1 23-12-2006 01:01 PM
ATTACK ON ME, WHAT WHAT IS IT ? U COULD ALSO BE ATTACKED eureca_eureca Software Q&A 18 10-05-2006 10:22 PM
Attacked by Virus freezer Software Q&A 8 29-12-2004 12:03 PM
