well any one started using it ??
Here is what i found ... I requested Navjot for an Invite
as u need to have invite to join joost
My hardware,
E6600
P5N-E SLI
XFX 6200 128MB LE...
1GB DDR-II
17" LG CRT
Windows XP SP Pro
BSNL 9000 Business (2mbps)
DataOne Home 500 (to test what will happen with upto 2mbps)
working with 1152x864 resolution
1st thing after getting an invite is, Downloading the Joost Player !! some 10 MB is the size... pretty simple install.... After u install appliction will ask you for creating user name password etc...
Pretty nit-clean interface... Easy to understand...
Here is the Main Interface... !!!
The Playing set up
Channel Guide
Will present 3 button, 1st One is to play the channel, press
i to get Text info in the channel, and
> to go in to channels Deep program search !!
Deep Program Search
You also get Channel Catalog to search in
It starts with a suggested program.. or u may select channel and program of ur choice..
So hows the Quality !! Well I have to say with working with 1152x864 resolution i find quiality isnt bad at all, yes i cant expect DVD / TATA Sky quality in 2mbps but seems good...
Brightest point is, with both connection Home 500 and Business 9000 I didnt get any lag at all... played smoth...
Technology is gr8 only the Porgrams sucks
didnt find any good program to watch.....
How about Bandwidth consumtion ??
I played it for all most 1 hours in Home 500 and half an hour with Business 9000, it ate up 215MB in home plan but strangely enough almost same ammount in Business 9000 but in half of the time... (Note Run firewall to make sure its only joost which is accessing the net, did monitor all activity, no other program was download
But One more thing, its a resourse hungry application for sure...
Running with 1GB i didnt feel any pain though those who are running 256MB will face problem... (note, many Laptop users are still with 256MB RAM)
so over all view, Program, Interface and performance is very good, but lacks quality programs to keep a viewer stick with the service...
So then, what is ur view guyess ??? any one else playing it with different settings ??
What Is jost ??
Request Joost Invite
