~Image
I have created a folder with this trick
((((((((((first create a new folder somewhere on your hard drive
when you name it hold down "Alt" and press "0160" this will create an invisible space so it will apper as if it has no name.Then right click and select "Properties". Select the tab "coustimize" and select "change icon". Scroll along and you should see a few blank spaces. Click on any one and click ok.)))))))))))))
But after creating this folder and CHANGING ITS ICON ,i find that this folder is not deleting ,the delete command seems to be not working on it .............
help me out !!!!!!!!!!!!!!!!!!
