Old 04-05-2007, 04:06 PM   #1 (permalink)
vikasg03's Avatar
Default how to remove rrpcsb.exe
in my IBM laptop daily one file is there " rrpcsb.exe". is this a virus?. when i try google i got one info "It is not a Windows core file. The program can be removed using the control panel Add\Remove programs applet. rrpcsb.exe is able to record inputs, monitor applications. Therefore the technical security rating is 38% dangerous. " .
another info is "This file is part of an IBM TCO Software package that is supposed to help users recover data in case of a system failure.
" but i cannot found it in add remove prog. Anybody knows how to remove them. i daily delete the file. it creates daily when i open my laptop
Vikas
vikasg03 is offline
Old 04-05-2007, 04:28 PM   #2 (permalink)
aryayush's Avatar
Default Re: how to remove rrpcsb.exe
'Windows + R'
msconfig
Startup items (or something like that)
Uncheck ' rrpcsb.exe'.
It won't start the next time you boot into Windows.
aryayush is offline
Old 04-05-2007, 04:44 PM   #3 (permalink)
Security Exp
47shailesh's Avatar
IBM Rapid Restore is installed on IBM Thinkpad Laptops and is designed to restore your computer to a functional state.
Source:http://www.fileresearchcenter.com/R/....EXE-1662.html
it's safe no need to panic or remove from startup.
We Love Once, And When We do We do it Well
47shailesh is offline
Old 04-05-2007, 09:29 PM   #4 (permalink)
Distinguished Member
anandk's Avatar
it shud be situated in C:\Program Files\IBM\IBM Rapid Restore Ultra\
if situated elsewhere like windows or system32 folder, it cud be malware. so check up its properties or get the file tested at http://www.virustotal.com/en/virustotalf.html
i think u might want to have it in ur startup list if its the legit IBM Rapid Restore file.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
how to remove imported_tarang QnA (read only) 6 17-04-2006 03:54 AM
Win 2K Remove speedyguy Software Q&A 3 15-07-2005 03:04 PM
How can i remove this......... nipun_the_gr8 QnA (read only) 17 08-12-2004 04:15 PM
How can i remove........... nipun_the_gr8 QnA (read only) 2 02-12-2004 01:57 AM
Is there any sw to remove... sms_solver QnA (read only) 3 28-11-2004 07:22 AM
