Old 04-05-2007, 01:28 PM   #1 (permalink)
Post PC shuts down automatically
Now a days my Computer is sufering from peculiar problem ..as its shuts down
automatically without any prior notice or error mesage.
it usually happens while i work over office 2003 word application with IE7 with
more then 5 tabs...it it sounds very rubbish ...
1 .I replaced my UPS but the problem is still there...
2. checked the CPU fan and its giving the regular performance. ( i got only CPU
fan installed in system as no System Fan is available ...as no AC installed in
the room i work under room tmeperature but never experienced this for past 2
yrs.
3. checked each and every plug or socket ..everything functioning normally.
wht u guys think do i nned to install another system Fan or its software
failure...
do leeme know as its troubling me a lot..?/???
System Configuration
XP Home -Service Pack 2 Original
HCL -x86 based PC
Memory: 256 MB
Page File -606 MB
Hardisk -40 GB only( 2 Partitions ) 1 GB free
i love everything which comes up in my life ,don\'t mind ups and down ...
sanjubuddy is offline
Old 04-05-2007, 07:03 PM   #2 (permalink)
Default Re: PC shuts down automatically
Go to System Properties (Right click on My Computer and select Properties), go to Advanced Tab and select Settings Button in 'Startup and Recovery' section. Deselect the check box for Automatically Restart here... Now, you should get an error message before restart happens... Note the error message and post here....
Also, it may be possible that this happens due to dust in RAM module, failing RAM module, overheating, etc... You might want to check for these too...
Arun
sakumar79 is offline
Old 04-05-2007, 07:27 PM   #3 (permalink)
Though not the one who posted the question,
I did not think think of dust in RAM as a possiable cause.
CoolDivya
http://www.Upload27.com - Upload files and images upto 2GB with a Realtime Progress bar, absolutely FREE. No registration required.
cooldivya is offline
Old 05-05-2007, 12:02 AM   #4 (permalink)
Question Re: PC shuts down automatically
Arun
its not about restart ,its just shuts down automatically .....
Old 05-05-2007, 04:45 PM   #5 (permalink)
HI friend
this is the cause of " smps". just check wheather it working properly or not and its fan should runs smothly .if it is not working properly or damaged just get it repaired or it will be better to purchage new smps . instade of installing win2003 office , install office xp. then give the reply.
suraj is offline
Old 18-06-2007, 01:58 AM   #6 (permalink)
Post Re: PC shuts down automatically
Originally Posted by suraj
HI friend
i installed AC in room ,and now computer is functioning normally...
Arun
it shuts down completely...and doesn';t respond...for a 1/2hr..till it cools off....tell me how to check CPU temp..and wht's the normal temperature of CPU
6600 shuts off automatically djmykey Mobiles and Tablets 12 25-10-2006 07:33 AM
computer shuts down suddenly gary4gar Hardware Q&A 4 30-03-2006 08:47 AM
pc shuts down with dis warning everytime!!!!! KoRn QnA (read only) 41 23-02-2006 04:52 PM
Computer Shuts without Warning navjotjsingh QnA (read only) 7 13-10-2005 08:56 PM
ms word shuts down automatically ... saurya_mishra Software Q&A 4 24-07-2005 06:40 PM
