Old 14-02-2005, 01:59 AM   #1 (permalink)
Web Entrepreneur
ShekharPalash's Avatar
Default 2 DATs in 1 CD... How?
I've 2 DAT files of a campus fest each 544 MB from 2 VCDs... now i want to compress them in a single 700 MB CD...??
Is it possible ??
Which compressions to use... DivX / WMV 9 ??... or any other format is better than these two??
I'm new to all these video editing/conversing/compressing stuff... also pls tell me any software to convert them...
I've Windows Media 9 Encoder and DivX Codecs [which comes in DVD] installed...
Thanks
ShekharPalash is offline
Old 14-02-2005, 03:08 AM   #2 (permalink)
busyanuj's Avatar
use Dr. DivX software and convert those dat files into DivX videos, then those two files can be burnt onto a single disc.
when you burn the disc, also remember to put the divx bundle installation file in it, so that all the other people who share that disc (and don't have divx installed) can install the codec and see the videos.
busyanuj is offline
Old 14-02-2005, 04:07 AM   #3 (permalink)
great information man
i too dont know about it!!!
thx
neerajvohra is offline
Old 14-02-2005, 07:16 AM   #4 (permalink)
The Photoshop Guy
cooljeba's Avatar
You can also use virtual dub and compress the video to divx and the audio to mp3 so overall a smaller divxfile
I have done once i compressed the matrix revolutions 2 cd's in to one cd.
..:: peace ::..
Jeba
cooljeba is offline
Old 14-02-2005, 11:09 AM   #5 (permalink)
Using Virtual Dub might just pretend to be much more HECTIC so i would suggest U to go for Div X the best!!
enjoy
At times in ur life just to do things right U have to be steady & sacrifice sth which u want the most.....even ur dreamzz tooo....
yehmeriidhain is offline
Old 14-02-2005, 11:37 AM   #6 (permalink)
Ethan_Hunt's Avatar
such an old member but still no time to search....ehhhh
http://www.thinkdigit.com/forum/viewtopic.php?t=14561
http://www.thinkdigit.com/forum/viewtopic.php?t=14057
Btw Xvid Codec would be beneficial for ya.... 8)
Ethan_Hunt is offline
Old 15-02-2005, 07:07 PM   #7 (permalink)
Web Entrepreneur
yeah man... i do search most of times, especially b4 making any new post here in Q&A section... but didn't searched tht time... look at time when i posted this... it's 2 am.. i was feeling slllleeeeeepppppyy tht time...
hey thnx for links...
i used dr. divx and compressed both DATs 2 a VCD
Live Chat with Doctors 24x7 on my site http://healthcaremagic.com
Old 15-02-2005, 11:35 PM   #8 (permalink)
parthbarot's Avatar
u can use virtualdub or flaskmpeg for that to convert to avi & u can use DivX / Xvid codec...
u have to install codecs any of above...Xvid or Divx...
Xvid is freeware..DivX paid
flaskmpeg(freeware) is best for DVD IFOs & VOBs.& mpgs..doesnt support DAT...REsume supported hai..
VirtualDub(freeware) is also good..suports DAT but Doesnt support IFO or VOB..also not supports "Resume"...
calculate size for files by lenght & get bitrates as u neded by using "Advanced Divx Bitrate Calculator"..
bye
regards
www.techlads.com
Paarth.
parthbarot is offline
Old 15-02-2005, 11:52 PM   #9 (permalink)
Web Entrepreneur
job's done already with dr. divx
but, hey thnx for more info u've given
Old 16-02-2005, 12:20 PM   #10 (permalink)
IMp Imp
Use Xvid it kicks the ass of divX.
Although I couldn't believe it intially but it works better than divX.
Go For It
Don\'t assume. It makes an ASS out of U and ME
tushar_novice is offline
Old 16-02-2005, 10:27 PM   #11 (permalink)
very few differences
the only major diff is xvid is free
divx isnt
for more on formats read maverickrohan's post on "best video codec"
theraven is offline
Old 17-02-2005, 01:08 AM   #12 (permalink)
parthbarot's Avatar
ya but main prob is that if u have created video with DivX codec then may be it gives u problem by Direct Show..it means that the XviD cant decode it properly..(may be...may not...)
my one video is not running...shows slowwly when uninstall DivX 5.2 pro from my PC & with Xvid....
so u have to install both codecs...to see properly the AVIs...
in future new VxiD may be grt ..can defeat DivX..
but ya XviDed fiel is load fasts then Divxed file.....thats the grt thing & same size & quality u achieve...
regards
www.techlads.com
Paarth.
