i have got a mobile from korea in which there are many midi files with voice which sound as qualatitive as mp3 but in 1 mb memory it self there are lots of song about 15-20 ....becoz of midi file
so how can that mp3 file can be made midi (normal midi soft doesnt support voice i think)...
can it be used it web..to upload songs and such things...
thanks for help
be who u r :
Midi can't hv voice. Those files must hv some other extensions.
There r lots of softwares available on net to convert MP3/Wav files into Midi but all are crap.
Midi doesn't have voice track in it. But .mmf format which is a midi fromat has additional voice track support. .mmf is the standard for Samsung phones, where .amr and .mp3 files won't work.
So the midi files which you are seeing may be actually .mmf format files
__________________ Simplicity is the ultimate Sophistication HP dv6 6121tx: Core i7 2630 QM | 4GB | AMD 6770M 2GB GDDR5 | 640 GB
Nokia N86 8MP
the properties in mobile also says it is MIDI file
i also use to think that midi dont have voice
no it is not mmf
any way i will try to confirm it in computer
