Old 13-08-2004, 03:46 PM   #1 (permalink)
Default Overclocking of P4P800-VM
Hey buddie,
do any one tell me can we over clock P4P800-VM cause FSB is fixed in it
so if there any way to do it tell me
Music is like Sex, The more you get, the more you want.
demoninside is offline
Old 17-08-2004, 09:14 AM   #2 (permalink)
dont think u can oc much as ur mobo has onboard graphics and probably wont allow oc'ing. u can try resetting the motherboard jumpers to get a little bit more juice. another thing u can try is enable 'memory acceleration mode' under 'chipset configuration' in the 'advanced' menu of the bios setup. this invokes a feature of ur mother board similar to 'pat'(performance acceleration technology) availabe in higher intel chipsets like 875p.
technomodel is offline
Old 17-08-2004, 09:18 AM   #3 (permalink)
but mind, pat is nothing similar to oc'ing. it just decreases the memory access timings by using abypass path.
Old 17-08-2004, 11:56 AM   #4 (permalink)
I m not using onboard though, having a AGP , nd then tell me some more about to OC it. cause memory map doesn`t works
Old 17-08-2004, 05:57 PM   #5 (permalink)
use softwares like clockgen or bios rev, use google to get them. and see if u can change vcore or ram latency. otherwise wait for somebody better informed about the board. anyway, boards with onboard graphics have never been known for their oc'ing capabilities, whether u use agpcard or not.
Old 18-08-2004, 11:19 AM   #6 (permalink)
Thankz any way technomodel
