| Forum |
#1 (permalink) |
Cabinets Sunbeam Clear Acrylic Mid-Tower ATX Case If your PC has an extreme inside loaded with the best that technology offers, there is no better case to depict its vitals than this one. These see through acrylic cases are well made and very attractive. The cases have a mid-tower design and can take up to a total of fans. ![]() Chieftec Blue Dragon Aluminum Mid-Tower Case These cases are the perfect choice for gamers. They have a great mid-tower design, rock steady construction and are loaded with 10 bays. The cases come in a whole range of colours. Its innovative clear side panel sparkles with life leading any gamer into temptation. This case offers compatibility for all leading motherboards including AT, Baby AT, ATX and Micro ATX and provides plenty of room with 7 expansion slots. The large front-panel vent system allows maximum airflow and the side-panel exhaust disperses heat faster and more evenly than most other cases. The front swing-out bezel cover can be locked for security, and the side panel and drive bays both feature quick-release hardware. ![]() X8 Silver ATX Mid-Tower Case With its sleek look and smooth curves the X8 is an attractive mid-tower case with ample drive space. It comes with a large side window, and an LED in the front that changes colour. The X8 is a block of heavy steel. With plenty of cooling provided the case seems like it will never heat up. The X8 comes with three 80 mm fans, one in the front and two at the side. It also has provision for five optional 80 mm fans, of which three are in the front and two at the back. ![]() CrazyPC Biohazard and Silver Fire Dragon Case Mods This is what bragging is all about. The cases will make anyone beg and drool with lust. The CrazyPC Biohazard is made from the Lian-Li PC61 case, while the Fire Dragon is made from the Lian-Li PC60 case. They include laser cut Window Panels and an optional Cold Cathode Light Kit. Key features include aluminum construction, tool less entry, removable motherboard tray, and four case fans. ![]() The aluminum body is lightweight and sturdy, and offers superior cooling performance. The anodized aluminum panels are precision cut by laser for a professional and high quality look. The panel has a clear acrylic that is fixed using high quality clear 3M adhesive. ![]() Inferno Max The Inferno Max Case Mod is the hot stuff; this flaming design is one of a kind. This modified case is based on the Lian-Li PC-61 Mid-Tower ATX case. The case is made of aluminum and has a beautiful and durable anodized finish. The base version of this mod includes the laser cut Inferno Window Panel. The design features two Skulls with trailing flames and an integrated 80 mm Fan Cover design. The case has two front fans, one vented top fan, and a rear fan that provide superior cooling performance. ![]() Lightning Mod This cracker is the stuff that dreams are made of; the Lightning Mod is made using a Lian-Li PC-70 and an integrated 8-inch Blue Luminglass Lightning Display with a custom Lightning Bolt Window. The Luminglass sound activation and on/off switch is in the lower left corner of the window panel for easy-access. On the top of the case is a Top Window with 80 mm blow hole and blue 4 LED Fan. And finally, a blue dual cold cathode light kit to light up the interior of the case. The Lightning Mod definitely thunders. ![]() Wrap me up You spend a bomb on your case; you tirelessly and affectionately paint its corner with love and shower it with your most creative designs... only to see it all scratched away. In order to make an impression, sometimes you could end up spending a bomb, and then eventually loose out because your beautiful case is full of cuts and scratches. This is where case wraps come in. The practice of wrapping cases in contact paper, wallpaper, and other adhesive substances has been known for several years now. Case Wraps are printed vinyl that offers an easy and affordable solution to beautify your PC. ![]() Keyboards Eluminx Eluminx keyboards not only look cool and trendy, but are also useful. For all those night animals out there, these keyboards allow you to type in the dark without disturbing the rest of the household with switching on any eye blinding lights. The keys are clear and backlit by ElectroLuminiescent technology that glows with a soft blue light making them easily identifiable in the dark. The keyboard has a comfortable feel and the construction is solid. Great for dim-to-no-light conditions. ![]() Fans Big, bright, psychedelic Fans If everything else is glowing but you still have that dejected black plastic fan hovering around somewhere, now wouldn?t that be tragic? ![]() Dressing your PC up would be incomplete without putting a UV fan in. UV fans are cool and have excellent functionality. Put a couple of superbright LEDs in and you can use your PC as a solar heater. Having them would make your PC a superstar with lot of fans. ![]() Antec 80 mm Trilight LED Fan The two-pin Trilight LED fan adds flair and personality to your PC. It is equipped with three LEDs (red, green and blue) and weighs a measly 71.5 grams, spinning around at an average 2,600 rpm. Its silence adds the jazz to your cabinet without any music giving it the blues without any sorrow. ![]() Cost Rs 850 Cold cathodes are the ultimate spice masters, without them, any computer will have just another ordinary funereal. Cold Cathodes bring the band in, play some loud music and get the crowds in a frenzy. Cold cathodes look best when served with a computer having a side window, they can remain frozen for up to twenty years. Put one of these for your next LAN party and expect amazement, put many of these and expect a riot. ![]() Power Supplies Antec TrueBlue 480W Conventional power supply designs have a single output circuit for supplying both the +5V and +3.3V output. Sharing the same output handicaps the PSU?s ability to deliver maximum power, when required, to each output simultaneously. The TrueBlue on the other hand is designed with a dedicated output circuitry for +3.3V, +5V and 12V, allowing maximum power to be delivered to all voltages, thus assuring maximum performance when your system needs it the most. The Voltage Feedback circuitry maintains accurate voltage to all components, further assuring ideal performance and stability. Attaching it the first time may cause some tiles to break when your jaw drops to the floor. The blue LEDs light up giving the two fans on the power supply a surreal blue aura. But don?t let its cool charisma fool you; the TrueBlue power supply turns into a power-breeding monster when plugged in, it breathes energy into each and every component of your PC, livening it to shivering capacity. Antec?s low noise technology ensures that all this takes place without even a whisper. It has got a hefty number of power connectors and operates at a temperature range of 10? to 50? C and at a frequency of 47 Hz to 63 Hz. It weighs around 2.5 kgs, which is quite heavy compared to other power supplies. The TrueBlue power supply looks good and sounds even better without compromising on performance and strikes the optimum balance between noise reduction and necessary cooling. ![]() ![]() Costs :- Rs. 7300 If you want to purchase any of these products or find their prices, etc. www.crazypc.com and www.casemods.com This Thread is completely for Case Mod Lovers taken from Techtree.com Enjoy And post your views |
| Bookmarks |
| Display Modes | |
