Old 02-05-2007, 10:38 PM   #1 (permalink)
Unhappy HDD Problem
hi everyone i need help on HDD problem. I have 40gb samsung HDD with 4 partition. My problem is that when i connect this drive with my system it goes hang on the frist most screen of system and show only the of intel company MY borad is D850MV model 2002. PLz help how can i use my this drive wheather its slave or master.
sushantsaurabh is offline
Old 03-05-2007, 05:43 PM   #2 (permalink)
Shalu_Sharma
Posts: n/a
Default Re: HDD Problem
Well do you really think its problem with your hard-disk.
Check that your CMOS battery is not dead in which case u need to press F1 to enter the system.. Then find a friend who has a computer. Test your harddisk there. Better format it if you can. and repartition it.
Old 03-05-2007, 06:57 PM   #3 (permalink)
TechTin.com
ravi_9793's Avatar
read my last post in this thread
SATA HDD 160GB- BIOS not detecting
Make sure first Boot device is set to hard disk in BIOS.
ravi_9793 is offline
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
