Old 02-05-2007, 04:01 PM   #1 (permalink)
You gave been GXified
gxsaurav's Avatar
Default MacOS X : Got it running on PC finally
Well, after some trial & error & accidental deletation of many downloaded TV Shows, Zeeshan from this forum was able to run MacOS X 10.4.6 on his PC finally. Well....we will be disecting it soon compleately more then we disected Windows after his exams end.
This is just the begaining, MacOS X installed using the compatibility patch & since his PC only has onboard graphics he had to disable many things to get some speed, but now it is working quite speedy. Mac isn't that easy to use as Macboys say it to be. Enter key renames, to take a screenshot you have to press alt+shift+3 while the print screen key doesn't work & many other things. Lets see if it really is what the Mac users say it is.
In 30 mins, I tried quicktime which hanged cos i draged & droped a video file in it. Well on 2nd try it worked. But still failed to play cos it was XVID.
One problem with HSF is that is journling type file system. Means if there is a electricity cut or system crash chances are that the file system or file will get curropt. Actully this happened with him just now as lights went out & his UPS power also went down in few minutes. I hope he won't need to reinstall MacOS again.
Finder, don't talk about it. This is simple rubish. Even nautilus was better.
You cannot uninstall those apps which are in the form name.app using the usual drag & drop method to trash. You will need a perl script, well...so much for ease of Software uninstallation.
One very genuine flaw of MacOS X is that we cannot resize a Windows from any angle just the south east corner
White colour theme, he likes it but I am looking for some black color theme. Mac users if you know of any dark color theme let me know.
Aplications do not full screen. They just don't & Mac is full of palated UI which might be good for some users of Mac. I tried safari which is good in opening pages, but then i found he was on the 2 Mbps line , obviously pages open fast.
Just a few videos I made & a screenshot of his computer. He will be continuing this thread alongwith me to enlighten everyone how good or bad MacOS X is as said by some users.
You can download the introduction Video here
The geenie effect.
about.me/gxsaurav
gxsaurav is offline
Old 02-05-2007, 04:11 PM   #2 (permalink)
Default Re: MacOS X : Got it running on PC finally
its really long time since i m using osx on my pc, but i still cant figure out how to install my nforce LAN :S there a guide on insanely mac forums but that doesnt work for me
can u help me???
edit:
my config
AMD 3000+
asus A8n vm csm
512 mb ddr
160 GB(xp) + 80 gb(ubuntu) + 10gb (OS X)
i m using realtek NIC for internet
Ravirdv is offline
Old 02-05-2007, 04:15 PM   #3 (permalink)
gxsaurav's Avatar
sorry, we both are Mac noobs & nforce isn't officially supported so cahnces are it might never work. So flaw..
1) MacOS is good & stable cos it runs only on it's own hardware despite of that hardware being a PC.
about.me/gxsaurav
gxsaurav is offline
Old 02-05-2007, 04:20 PM   #4 (permalink)
its true coz even AMD cpus are not *Officially* supported i thought u might also be using nforce and might have same problem thats y i asked
but for me OS X is speedy, stable, and it boots extremely fast just have to make nforce LAN working then i can throw my xtra NIC
have to search some hackd drivers lolz
Ravirdv is offline
Old 02-05-2007, 05:31 PM   #5 (permalink)
aryayush's Avatar
You are new around these parts. I have a simple, friendly advice for you. You have got the wrong person to discuss Mac OS X with (as I am sure you can judge from his first post... and the second and the ones he has posted before this in other threads - basically every single post he has ever pressed the 'Submit' button for on this forum).
You are looking for people like goobimama, mail2and and nepcker.
You've been using it for months so I am sure you know its pros and cons (if there are any) already. Just do yourself a favour and please check up whatever he says on Google before believing it. This simple excercise can prevent you from severe misdirection.
And always do remember that if you run Mac OS X on a PC and are facing some problems, they are most probably due to your PC, not due to the operating system (because Mac OS X is not supposed to be run on normal PCs).
aryayush is offline
Old 02-05-2007, 05:58 PM   #6 (permalink)
The Devil's Advocate
iMav's Avatar
Originally Posted by aryayush
because Mac OS X is not supposed to be run on normal PCs.
and not even on high end ones
btw gx me too wanna try the OS X heard abt so much from every1 ... no pun intended arya ... seriously wanna try it
http://beingmanan.com
iMav is offline
Old 02-05-2007, 06:06 PM   #7 (permalink)
aryayush's Avatar
The best way is to go to an Apple authorised reseller and see a demo. Doing it the illegal way is not the way to go. And you will certainly hold the operating system responsible for all the troubles you are bound to face.
aryayush is offline
Old 02-05-2007, 06:16 PM   #8 (permalink)
Proud Mac Pro Owner
nepcker's Avatar
Yeah, OS X is supposed to run on Macs, not just any PCs of any configuration.
Microsoft Certified Professional Mac Addict
nepcker is offline
Old 02-05-2007, 06:33 PM   #9 (permalink)
Google Bot
Pathik's Avatar
Even i was thinkin to do this since long but didnt get the time??
@gx/zeeshan r u dual booting os x and xp or hav u installed only mac in the hdd??
Pathik is offline
Old 02-05-2007, 06:48 PM   #10 (permalink)
iMav's Avatar
@ arya i did that i have a new apple service centre near my house i did go thr but cudnt spend a lot of time thr coz i actually found the mac to be a little alien to me but never the less i have a portable version of mac OS 7 and tht i think is legal will give tht a try ... i think i can compare it to some version of windows
iMav is offline
Old 02-05-2007, 06:53 PM   #11 (permalink)
I see right through you.
Sykora's Avatar
I've been thinking of doing this for time sometime as well. If Zeeshan can post how he did it, it'd be nice.
I didn't make the world, I only try to live in it.
http://lucentbeing.com
-- Sykora --
Sykora is offline
Old 02-05-2007, 06:56 PM   #12 (permalink)
Google Bot
Pathik's Avatar
well here are some installation guides... i think they are perfectly legal.... if not, the mods can remove the links...
http://osx86project.org/
http://wiki.osx86project.org/wiki/in...llation_Guides
Pathik is offline
Old 02-05-2007, 07:00 PM   #13 (permalink)
sivarap's Avatar
U stole the words from my mouth Sykora.
sivarap is offline
Old 02-05-2007, 07:04 PM   #14 (permalink)
aryayush's Avatar
What the guides are describing is illegal. It is no better than mentioning a warez website.
You don't even need to try it out. Let me tell you, it is absolutely crap. Even Mac OS 9 was horrible. Mac OS X is nothing similar to any other version of Mac OS that preceded it. It is based on an entirely different architecture. If you cannot try out Mac OS X, don;t try any at all. That's a friendly bit of advice.
aryayush is offline
Old 02-05-2007, 07:29 PM   #15 (permalink)
C# Be Sharp !
Zeeshan Quireshi's Avatar
well OSX is beatutiful no second thought in that , but it fells a bit diff , although i'm adjusting to it
There are 10 types of people in the world: those who understand binary and those who do not.
Zeeshan Quireshi is offline
Old 02-05-2007, 07:31 PM   #16 (permalink)
iMav's Avatar
well i kinda knew tht so havnt tried it as of yet
in tht case my lunch is gonna be in tht guys new shop across the road
iMav is offline
Old 02-05-2007, 07:34 PM   #17 (permalink)
C# Be Sharp !
well me doin dual boot with XP
well it was quite a bit of a problem to get Mac OSX to boot up after installation .
now , here's how i did it
1. Download Mac OSX 10.4.6 Tiger image in July 2006(Yes 2006 )
2. had been lying around with me when i decided to give it a try
3. simply booted off da disk
4.installer took bout 15 mins to pop up
5.went to Utilities->Disk Utility to partition my hdd
6.Disk utility went bersek , it erased my whole hDD even though i clicked on a single partition n selected erase
7. i recovered my partitions n then i thought let's try it again ;D
8. this time disk utility didn't delete my whole hdd(i did same thing , clicked on partition n selected erase) but it messed up my downloads partition n i couldn't recover it this time , it was gone for sure , now had nothing to loose (btw , xp partition was still intact)
9. installed by clickin next->next->next ( a la windows )
10. botted of hdd , didn't boot , checked n found out partition containing OSX was not marked as active , marked it as active
11. tada , mac boots perfectly , every single peice of hardware is working perfectly (thanks to JAS for the Intel Patch n Drivers )
Old 02-05-2007, 07:40 PM   #18 (permalink)
Google Bot
Pathik's Avatar
k... not as adventurous as i had thot.... or as the guides said...
Pathik is offline
Old 02-05-2007, 07:52 PM   #19 (permalink)
C# Be Sharp !
and y r u using 10.4.6??? any reasons???
sure , coz i said i Had dvd lying around which i downloaded in July 2006 , that's y it was version 10.4.6 , so installed it just to test drive
Old 02-05-2007, 07:53 PM   #20 (permalink)
Debian Rocks!
freebird's Avatar
Windows support task force here,am i right?
"The day windows users wake up to reality, it will be doomsday for Microsoft."UNIX like OS are more secure.get urself out 4m M$ http://whylinuxisbetter.net http://tinyurl.com/2amjjc http://fsf.org
freebird is offline
Old 02-05-2007, 07:55 PM   #21 (permalink)
sachin_kothari's Avatar
i have tried Mac OS X 10.4.7 on VMWare.
it worked flawlessly once installed, though it took me 3 days to figure out how to install.
sachin_kothari is offline
Old 02-05-2007, 07:59 PM   #22 (permalink)
C# Be Sharp !
adventurous , i Actually installed it 11 times to get it working and most importantly i Lost 30 Gigs of Dragonball Z episodes , 32 GB of OC Episodes , 6 Gigs Of LOST Episodes , 10 Gigs Of movies , My Whole Program Files Folder , 150 Gig of music collection , now that's quite a loss .
ahh , all we were missing was a Linux taskforce
Old 02-05-2007, 08:01 PM   #23 (permalink)
even i lost an entire partition of 30 gigs when trying to install natively.
i gave up after that.
but i still have that vmware image.
Old 02-05-2007, 08:10 PM   #24 (permalink)
C# Be Sharp !
i tried it on VMWare but couldn't get it to boot after install so had to do real install
btw , Aryayush , how do i get the middle mouse button to work so that smotth scrolling works ?
i lost total 210 GB of data , n dunno what the partitioner did the second time i couldn't recover a single file even after running recovery soft for whole night
Old 02-05-2007, 09:49 PM   #25 (permalink)
Karthiksn
kato's Avatar
Quite a remarkable feat I must say and sorry for your loss(my heartiest condolences.)
"Walking the Path of Heaven, The Ruler of All."
kato is offline
Old 02-05-2007, 10:22 PM   #26 (permalink)
iMav's Avatar
wud be it safer to create a partiton before running the install
iMav is offline
Old 02-05-2007, 10:33 PM   #27 (permalink)
yes, but i didnt understand what partition it is erasing.
i created an empty 30 gb partition, but it deleted some other partition.
dont know why.
Old 02-05-2007, 10:47 PM   #28 (permalink)
gxsaurav's Avatar
@Freebird
The problem with MacOS X is that it expects you to either have a compleately new unformated harddisk or an existing HFS partition. If you have a harddisk with FAT32 partitions etc i will remove it cos it is looking for a proper Macish HD.
A better way is to boot using Linux live CD & make a 10 GB HFS Partition for MacOS X. Now boot from the MacOS X DVD & installin this this 10 GB Partition. Also make a FAT32 partition so that you can share files among Windows & Mac in dual boot cos Mac doesn't support writing to NTFS Partition.
about.me/gxsaurav
gxsaurav is offline
Old 02-05-2007, 11:23 PM   #29 (permalink)
Genius in making mistakes
bhushan05d251's Avatar
Question Re: MacOS X : Got it running on PC finally
Tell me the difference between Mac OS X Leopard Sneak Peek and Mac OS X Tiger. Also can I run Mac OS X on my computer? If yes then which Mac OS X better for me? My PC config is as follows:
1 GB RAM
1.8 GHz Intel P4
VIA motherboard (very old)
32 MB onboard 3D accelerated video memory (does not support pixel shedder)
DVD+-RW
40 GB HDD (15 GB-15 GB-10 GB partitions)
bhushan05d251 is offline
Old 02-05-2007, 11:44 PM   #30 (permalink)
gxsaurav's Avatar
You got a Via chipset. I advise not to install it. If you do want to then google is your best friend.
about.me/gxsaurav
gxsaurav is offline
"Apple, we have a problem" - Gentoo MacOS X aku Open Source 1 04-02-2007 06:30 PM
MacOS X 10.5 to feature new UI gxsaurav Technology News 9 14-12-2006 08:22 PM
My First K750i theme : MacOS X inspired gxsaurav Mobiles and Tablets 3 15-09-2006 02:38 AM
Have anyone tried MacOS ? Rosted QnA (read only) 14 09-07-2006 10:09 PM
Mozilla Firefox 1.0.5 for Windows/ Linux/ MacOS Released Curious Guest Software Q&A 5 24-06-2005 05:16 AM
