| Forum |
#1 (permalink) |
I currently hav Athlon 1.13GHz with 256Mb(SDRAM) with a Gigabyte Mobo with onboard graphics(a measly 8Mb memory one!!) Wel just tak a look at wat i need n then recommend the right one: AMD Athlon 64 FX or Athlon 64 Suggest a mobo which has onboard Bluetooth + SATA capability + PCIe(optional) A decent graphics card (the one with Ati Radeons 9200SE capabilities) And a 80 or 120Gb SATA HDD Just suggest me if this wil cost me less 20k if not can u suggest me alternative!! I require my new PC to last atleast 2 more yrs!! |
#3 (permalink) |
No need for a Monitor i hav a sexy 17inch Flat screen monitor!! I want a System which wil play most of the 3d games! I read the digit magazine carefully 2day they were of the opinion that PCIe is not much common with AMD mobo makers.So do u think i shud wait a little long??
Earth is full.Go home. |
#4 (permalink) |
AMD Mobo already have PCI-E support
The nForce4 Chipset for AMD Socket 939 Processors ASUS A8N - Sli Delux has support for 2 PCI-E x16 GPU's and 2 PCI-E x1 Cards Your budget is low to get this motherboard This motherboard itself cost Rs12000 approx. Edited Later ~~~~~~~~ Posted by Mistake its a Socket 754 AMD not 939 The S754 Processor will cost some 6-7K I dont know the rates for S939 but they are costlier than S754 variants |
#6 (permalink) |
It seems a mistake its a Socket 754 Pro which comes for approx 6K
Rates According to Digit Feb 2005 Pg 72 AMD Athlon 64 3000+ for Rs6716 AMD Athlon 64 2800+ for Rs6624 I dont have the rates for Socket 939 AMD Athlon 64 but just check it out. IF you are in Mumbai just go to Lamington Rd and you will get the best rates for AMD/Intel Processors. |
| Bookmarks |
| Display Modes | |
