Old 13-02-2005, 05:17 PM   #1 (permalink)
varunbhide's Avatar
Default cd-rw burning problems
i recently bought a moser baer cd-rw 80/700 mb disk and formatted it using incd 4. but while using it, it shows that it has a space of only 539 mb. is there a problem in burning or is the disk faulty? please help me out.
varunbhide is offline
Old 13-02-2005, 06:03 PM   #2 (permalink)
Let the music play.....
djmykey's Avatar
Default Re: cd-rw burning problems
r u sure u formatted it?? Coz in 4 years of my writing experience i never formatted a cdrw. U can erase it not format it. Which brand of cd r u using?? The cd might b faulty.
djmykey is offline
Old 13-02-2005, 06:06 PM   #3 (permalink)
vysakh's Avatar
the last time i formatted a CD-RW using INCD the space reached about 650 MB out of the 700MB
Incompatible message format
vysakh is offline
Old 13-02-2005, 06:13 PM   #4 (permalink)
i think u get that when u use that mt.reiner option . see if that was used . in cd seems to cause a lot of compatibility issues , especially when trying to access files within pure dos .
If you make yourself more than just a man, if you devote yourself to an ideal... You become something else entirely
klinux is offline
Old 13-02-2005, 06:13 PM   #5 (permalink)
why need title?
bharathbala2003's Avatar
hmm y do u need to FORMAT a CD i haven seen anyone doin it.. ppl only erase the data..
bharathbala2003 is offline
Old 13-02-2005, 06:21 PM   #6 (permalink)
swatkat's Avatar
Formatting using inCD reduces the Free space of CD RW, as the filesystem is a special one known as UDF.....this is normal....also the free space after formatting using inCD varies from media to media....
swatkat is offline
Old 13-02-2005, 06:27 PM   #7 (permalink)
swatkat's Avatar
inCD is a special tool, which makes CD-RW disks 'work' like a Floppy or HardDisk...after formatting using inCD, u can simply cut-paste-edit-delete and do whatever u can do for files/folders(as u do in Harddisks) in a CD-RW disk...it's a special file system known as UDF, and the method is known as Packet Writing.....
swatkat is offline
Old 13-02-2005, 06:33 PM   #8 (permalink)
why need title?
hmm i never knew bout this sware dude.. thnx for the info.. is it available online for free?? if yes link
Old 13-02-2005, 06:41 PM   #9 (permalink)
swatkat's Avatar
No it's not free...it's bundled with Nero...u can downlaod the Nero 6 Reloaded bundle demo...
http://www.nero.com/en/InCD_4.html
http://www.nero.com/en/Nero_6_Reloaded.html
swatkat is offline
Old 14-02-2005, 01:38 AM   #10 (permalink)
InCD is a good softwr. But no1 uses it though dats bcoz the UDF space hogger. Just use normal burning.
Ish Karo... Ishq karna Tumhara Paidaishi Haq Hai........
Magar Kyon Na Is Bar Watan Ki Mitti Ko Mashuka bana le!!!
:) http://www.aseemn.org
Aseem Nasnodkar is offline
Old 14-02-2005, 11:02 AM   #11 (permalink)
varunbhide's Avatar
the how do i use a cd-rw without formatting it? is there any other file system (other than udfs) which allows more space?
Old 14-02-2005, 11:40 AM   #12 (permalink)
swatkat's Avatar
UDF is only used for packet writing that is using it like a Floppy or Hard Disk...this reduces the toltal free space of the disk....
u can use it as a normal CD recordable media, that is u can burn data using any burning softwares like Nero, and u can make use of full 650 or 700MB....only advantage of CD-RW over CD-R (Recordable) is that u can erase the content of the CD-Rw and u can write it again....
swatkat is offline
