Old 01-05-2007, 02:44 PM   #1 (permalink)
Default Computer Messed Up! How to go about fixing it?
Hi
My dad has been affected heavily by a number of viruses and malware. Now he's given me the responsibility to fix his computer. Now, I would like to ask a few questions?
First of all his root drive is only 6GB. Whats the best tool I can use to increase the partition size without losing data?
Now, which is the best way to clean his computer? Completely install a new version of XP, or try to fix it using different anti-virus softwares? If so, which software should I use?
hitman050 is offline
Old 01-05-2007, 02:54 PM   #2 (permalink)
Sup' dude, Sup'
Default Re: Computer Messed Up! How to go about fixing it?
1) To repartition, use Partition magic 8
2) To fix virus issues, use Kaspersky antivirus. Boot into winxp safe mode and do a full scan.
ambandla is offline
Old 01-05-2007, 05:07 PM   #3 (permalink)
Hey best way is to install a fresh copy of windows xp by formatting whole of the hdd. As some areas are left by av's even cleaning. If you don't want to install a fresh copy us good av to clean. Use more than one.
abhijangda is offline
Old 01-05-2007, 06:39 PM   #4 (permalink)
ApoorvKhatreja's Avatar
To fix antiviruses, use Kaspersky 7 Beta. That way you can remove all the viruses for free. The beta has a free trial period of 91 days, and it is very fast and lightweight.
http://apoorvkhatreja.blogspot.com
ApoorvKhatreja is offline
Old 01-05-2007, 08:20 PM   #5 (permalink)
Pragadheesh's Avatar
Post Re: Computer Messed Up! How to go about fixing it?
as abhijangda said , wen ur computer s totally infected wid viruses n stuffs its always better to format yo entire hd and install xp. also u can increase d size of ur root partition..
Pragadheesh is offline
Old 01-05-2007, 10:15 PM   #6 (permalink)
What?
Ihatemyself's Avatar
Dont use partition softwares..they are all messy..formatting is better option..
And as per antiviruses use AVG Free edition 7.5...Thats pretty good (also on system resources) ...plz dont mind but give a better thread title next time so that we can get better idea about ur problem
Unremitting attention to horses neighing awesomeness is nothing to brag about.
Consider----------> Milking Cows.
Ihatemyself is offline
Messed up monitor settings and no X phreak0ut Open Source 8 28-03-2007 10:15 PM
msi messed it up ASH18MARCH QnA (read only) 3 24-07-2005 11:49 AM
Messed up while partitioning!Pls help. harpoon QnA (read only) 4 05-09-2004 07:14 PM
