01-05-2007, 02:31 PM
Can I connect multiple headsets to my PC?
Hi
i m curious to know this...is it possible to connect multiple headsets to pc...
01-05-2007, 03:09 PM
Proud Mac Pro Owner
Re: Can I connect multiple headsets to my PC?
No. The headsets have a 1:1 Connection to the device that it is connected to it is not possible to have more than one headset connected to the PC currently.
The multiple headsets can be paired at the same time, and switching between the devices is simply a matter of disconnecting one headset and connecting the alternate headset
Try visiting http://www.auvionix.com/multimediamixerapp.htm
It may offer some help to you.
Microsoft Certified Professional Mac Addict
01-05-2007, 06:02 PM
Thanks for link.....
01-05-2007, 06:19 PM
The Devil's Advocate
i think nepcker u r slightly mistaken ... i think it can be done by using a splitter
find something like this iv seen it in the market
http://beingmanan.com
02-05-2007, 11:24 AM
Proud Mac Pro Owner
I've posted a link about such a product, and I think mkmkmk found it useful.
02-05-2007, 10:20 PM
hi guys i have made a cuircuit for this and i m using my 2 speakers set both are seprate to each other & headphone. Just make a curicit with some parallel connections.
02-05-2007, 11:31 PM
String Phreak
If u mean same output to multiple headsets then just install a FM transmitter and then ur whole joint family can njoy listening to their personal wireless headset!
03-05-2007, 12:24 AM
quality suffers
03-05-2007, 06:49 AM
A splitter is sufficient and will not cost much... I dont think quality will go down and unless you are an audiophile, you wont notice any difference in quality... I use one of them, but it is not like mav3's picture... It is just a small pin on one end, a short body and two holes on other end...
Arun
03-05-2007, 07:40 AM
* Teh Flirt King *
Arun
I have the same one u r talking abt. And I dont think there is a quality loss.
03-05-2007, 03:19 PM
Arun
and when i said quality suffers i replied to mediator's suggestion of using a fm transmitter
03-05-2007, 03:33 PM
Wire muncher!
^^^ i'm using the exact same one. its dirt cheap and works fine... go ahead and use it... simplest way of getting the job done!!!
03-05-2007, 04:51 PM
The Techno Perv
just curious.... wat bout headsets with mike?? i mean wil 2 or more ppl b able to voice chat simultaneously using the above mentioned hardware attachment??
03-05-2007, 04:52 PM
@mav3, ok, I misunderstood what you said... and that pic that you show now is just like what I have... Good to know that we are all in the same page...
Arun
03-05-2007, 05:51 PM
Wire muncher!
@dtox
hmmm.. interesting thot.. gotta try it out!
03-05-2007, 10:21 PM
thanks to everyone,i got nice information from answers....
so we can use 2 devices to connect multiple headsets to pc..and 2 persons can watch n listen SAME movie......
1 splitter
2 FM transmitter
pls tell me probable cost of each one..?which one is cheap ?
thanks @mAV3 for pics,infra red dude.
03-05-2007, 10:29 PM
String Phreak
^Splitter is cheap, afaik is around Rs.20. I think splitter is best for u but I liked the other one!
I didn't experience any noticable quality difference yet!
03-05-2007, 11:08 PM
Wire muncher!
^^ yeah got it for 15 bucks... quality suffers if u haf "high end" ears and headphones. wid normal headsets/speakers the quality barely deteriorates... so no worries
cost of fm transmitters varies according to its power. i think wid just a 5W transmitter u can broadcast all over a small city. i'd made my own fm transmitter for abt 45bucks. got a cheap fm mic, ripped off the condensor and attached 3.5mm stereo jack to it and plugged onto the line out. it was mono but did its job well. i cud get the audio output in my car parked in garage. i used to live in 2nd floor. so the range was pretty good. i only intended to use it across the room. cheap and ghetto!  but bear in mind that u'll hafta spend on batteries or get rechargable ones. it adds to the cost.
04-05-2007, 12:21 AM
#19 (permalink)
String Phreak
^^yeah correct!
Its just like the difference between mp3 quality and cd quality......noticable only to the maestros!
04-05-2007, 07:17 PM
#20 (permalink)
thanks mediator...i m curious about both..will try one by one....
Search this Thread |
