V Y S T A L - Reloaded gives your XP the "WOW"!
It applies the Aero Glass effect to your XP borders just by one click.
It has also many features like customizing border...
An alternative to WindowBlinds ;)
*Latest Build*
» Author: JackHard dtd. 21.04.2007
» Size 0.29 MB
Vystal is a nifty little app that will give your Windows XP the Vista Glass Look !
It applies the Aero Glass effect on your window's border just by one click.
Features:
- Blur effect on all videocards
- Customize your borders
- Every opened window is being updated
- Run it on Autostart
- Search automatically for updates
^ he's talking of WB5 & transparency apps for msstyles. I have used them earlier. The app I posted is something different. Google for the WUI (memoria) theme for WB5. Its even better than aero.
:::::::::: When freedom is outlawed, only outlaws will have freedom ::::::::::
