Old 30-04-2007, 11:24 AM   #1 (permalink)
Pragadheesh's Avatar
Unhappy system not turning on..!!!
hi, i recently brought one of me fren's sys as he(hostelite) is going home... after doing all d connections d system s not gettin turned on.. i.e d monitor not gettin turned on.. instead 3 beeps as soon as i press d power button.. donno wat went wrong..!!! any help plz...
Pragadheesh is offline
Old 30-04-2007, 08:18 PM   #2 (permalink)
Fresh Stock Since 2005
Default Re: system not turning on..!!!
I think the problem is with the RAM.. In some cases removing to RAM from the slot and replacing it after cleaning around helps... Try it in a different slot.. But if it does not work, you will have to go for a new stick...
http://www.khattam.info
khattam_ is offline
Old 30-04-2007, 09:05 PM   #3 (permalink)
What?
Ihatemyself's Avatar
Hey dis is no place 4 spamming .we're out here to learn or help folks wid tech stuff...where is the moderator
Unremitting attention to horses neighing awesomeness is nothing to brag about.
Consider----------> Milking Cows.
Ihatemyself is offline
Schedule turning on of modem..... thetopcyborg Networking 5 24-08-2006 03:26 PM
WGA Turning Off PCs thunderbird.117 Technology News 2 30-06-2006 08:39 PM
CoolPDF 2.01,turning just about anything into a PDF. rajat22 Software Q&A 2 30-10-2005 09:23 PM
Turning your PC into a Web Server [lokesh] Tutorials 9 21-07-2005 06:54 PM
Turning on DMA suyash_123 QnA (read only) 1 01-02-2005 06:49 PM
